Keep calm and carry on
Started by Andy H, 27 May 2021, 11:41:17
ronnyd
Probably didn't even realise until someone told him.  ;D
Rangie
That's what happens if you mix toilet cleaners in the pan..😂
Varche
That is shocking.
Next days building? Poor batch of mortar?
Lizzie Zoom
I did notice a slight lump in the back of his kecks  ;D
Diesel till I die
One less Fester on the road too...
ronnyd
Too much Fairy Liquid in the mortar?  ;) DAVE!!!!!
dave the builder
Quote from: ronnyd on 27 May 2021, 18:21:46
even I use proper plasticiser and i'm a right tight arse   :D
not one of mine  ::)
no lateral bracing on the trusses and trusses not tied to the brickwork
so £100 worth of wood and ironwork missing has proved quite costly  :(
fortunately no one died  8)
shame "building inspectors " and "mortgage surveyors" don't bother to stick their heads through the loft hatch and check such things ,but it's OK because they print a disclaimer on surveys  >:(
Bloody builders  ::)
Quote from: dave the builder on 27 May 2021, 19:51:25
not one of mine  ::)
Bloody builders  ::)
Doubt a surveyor would have noticed that with a quick peek through a hatch. Mainly because no one would be looking for it, it's the kind of mistake you just wouldn't expect to happen.
Diesel till I die
dave the builder
Quote from: STEMO on 27 May 2021, 20:04:02
That's his JOB  ???
or HER JOB  :D
I'm not up on wokeness enough to know how to address a surveyor who doesn't identify as him or her  :P
Opti might know  :D
to look for major structural problems that may leave the building society or buyer with a pile of rubble
lots of things get missed on big sites by building control because they don't inspect every property as they go up, just a select sample  .
£500 to £1000 for a Survey that takes an hour at most and another hour back at the office to copy and paste all the disclaimers and press print , sounds like a nice little earner
A mortgage survey generally checks that the property actually exists, and that it broadly matches the description vis a vis size/number of rooms :-\
dave the builder
Quote from: Doctor Gollum on 27 May 2021, 20:37:20
2 types
1: mandatory ,will the lender get their money back if the borrower defaults  (which SHOULD include "is one of the gable ends likely to fall off ")
2: full survey ,which should pick up things like wiring problems ,plumbing problems ,damp/ventilation issues etc etc
though ultimately , the "builder" should have braced the trusses and tied the wall into the roof  :D
Shackeng
Quote from: dave the builder on 27 May 2021, 20:27:23
That's his JOB  ???
or HER JOB  :D
Opti might know  :D
Quite agree Dave. In my experience the pages of disclaimers are 10 times the size of the actual survey. My experience of surveyors has been dire, never finding the serious problems that exist.  >:(
