Author Topic: Battlebus (not) Starting  (Read 12445 times)
Re: Battlebus (not) Starting
« Reply #30 on: 14 August 2021, 22:44:31 »
https://www.ebay.co.uk/itm/203535853182 :D
I think you posted this in the wrong thread Al.  Looks perfect for Malc's new car to me!  ;D
Wrong wheel drive ;D
Which makes it perfect for the Battlebus transplant...
Oh... I thought all Yank Tanks had RWD and leaf springs!  :)
Only pick ups and performance cars ;) everthing else is fwd shitbox fodder
Raeturbo
  • South Wales
    • TouregR5Mitsi Evo2. XJ8
« Reply #31 on: 15 August 2021, 00:06:07 »
[/quote
               No it’s Wong wheel dwive.
Laying a rubber road.
« Reply #32 on: 15 August 2021, 01:25:30 »
[/quote
Like the Battlebus  ::)
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
« Reply #33 on: 15 August 2021, 12:51:00 »
This thread reminds me. I really must start trying to investigate why the hateful lump of plastic french shite, will not under any circumstances start when the engine is hot.  :(
Any fault codes, ie low rail pressure ?
other rides
Raeturbo
  • South Wales
« Reply #34 on: 15 August 2021, 12:58:13 »
Burn it🔥 you know you want to👍…. You know you have to…..   Do it!🔥🔥🔥🔥🔥
« Reply #35 on: 15 August 2021, 14:35:04 »
Me or Albs ;D
« Reply #37 on: 15 August 2021, 15:22:28 »
This is a different issue to the lack of working glowplugs ;D
When parked uphill overnight, it tends to die a few seconds after starting, and makes it a right pig to start again.  Parked downhill, its much better :).
I'm thinking leak off pipes, but a quick glance, the *look* ok.  Would I see diesel around them if they leaked?
Turn it round and park it downhill overnight. ::) :-X
Raeturbo
  • South Wales
« Reply #39 on: 15 August 2021, 16:38:56 »
Me or Albs ;D
                          You can make a pact🤓
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #40 on: 15 August 2021, 16:44:51 »
Burning either would produce thick .black, billowing smoke  :o
as would running their tractor juice diesel engines  :D
Raeturbo
  • South Wales
« Reply #41 on: 15 August 2021, 16:46:19 »
Fire is the answer :y
Migv6 le Frog Fan
  • Essex / Suffolk border.
    • 3.2 Elite. Citroen C1.
« Reply #42 on: 15 August 2021, 17:13:49 »
No codes present. Did have a FPR code but thats gone since I changed the fuel filter, as has its tendency to throw up the stop engine light and go into limp mode after 5 minutes at motorway speed.
I changed the cambelt not long ago, so shall revisit that and check timing first - then burn the little bastid.  ;D
« Reply #43 on: 15 August 2021, 18:24:23 »
Did this behaviour start with the filter change ?
Is the filter housing cracked?
Migv6 le Frog Fan
« Reply #44 on: 15 August 2021, 18:42:50 »
No it predates that.
Pages: 1 2 [3] 4  All   Go Up
