electric showers
Started by raywilb, 21 January 2022, 20:07:50
raywilb
 asking for recommendations for an electric shower. lots for sale but is the higher the kw,s the better it should be. ??
I think mine is 11Kw and I run it at 6.5
I would say the higher the power then the less stress is on the unit with power in resereve. :y
Cant remember the make and model of mine, but it's a power shower with high/low pressure. :y
Electric showers just run at a constant heat output (so nothing in reserve - unless it has a low/high heat setting). Temperature is adjusted by changing the flow rate. A higher rated one will therefore just give you a faster flow rate (and electricity consumption) at a given temperature.
Worth checking what your electrical supply can cope with before getting a hugely powerful one, and if a circuit is already present, you'll need to consider its rating.
Higher rated showers need a higher flow rate of water too
ronnyd
Also check that you have enough 'head'  :o to let a conventional shower work correctly. I still have a hot water cylinder which is not installed high enough for an ordinary shower to work, so had to go for a power shower which has an integral pump.
Raeturbo
As Kevin had said it is very important to find out if you have a heavy enough gauge
wire feeding it if you intend to upgrade the KW on your shower.
Laying a rubber road.
Been through a variety, they get quite a bit of use here.  Only tend to get a few years before a few bits pack up in them, then more cost effective and quicker to buy new than repair.
Found a Mira Sport 10.8 gives the best shower imho, ignore the airboost thing though, next to pointless.
Lizzie Zoom
#7
I have fitted 3, and used Mira Advanced Thermostatic Flex 8.7 KW electric showers, which for me are the best in that price range. It comes with a long hose if not
They will work on reasonably low water pressures if necessary, down to 0.7 bar, which I took advantage of when fitting one of these showers in my daughters house.  The previous cheap shower she had would not work if the pressure dropped, even though it had it's own direct cold water supply, taking it off the mains before any appliances / taps could reduce the pressure.  The Mira Advanced has not faltered and provides a strong flow at all times.
With one of my Mira showers I needed a spare part, and found the company has a very good service department who quickly supplied the part, and at a discount.  Highly recommend them! :y
If you have a suitable hot water supply  available but can't easily fit a mixer shower the Aqualisa Visage and Quartz ceiling fed showers might be worth a look although I notice they've facelifted them and considerably hiked the prices since I last bought one. ::)
These have a mixer and optionally a pump that can be mounted remotely in a loft or cupboard avoiding the need to chase pipework into the walls and replace tiling, and so on.
