vauxhall mokka tyre pressure fault
Started by raywilb, 29 July 2023, 17:45:45
Quote from: TheBoy on 01 August 2023, 17:23:02
Quote from: Field Marshal Dr. Opti on 01 August 2023, 14:24:26
TPM is a pain in the arse.
The system in my old Jag would always show an error message when the weather was  very hot or very cold.
Before I changed the battery, mine used to come on every time it went sideways.  With new battery, I only see it if the car has been left standing for a couple of weeks.
You really should go for black and round type tyres for a bit more excitement and the added driving experience!  ;D
Quote from: ronnyd on 01 August 2023, 15:11:39
A lot of these 'driver aids' are just  to pander to drivers who are to idle to check their car once a week. I also know when it's raining ,because i see these funny wet spots all over the windscreen.  :D
Who honestly checks their cars' tyre pressures weekly ... or even at all, unless they think a tyre is soft
I like the auto wipers on my ML .... but I manage quite well with our other cars that don't have it  :y
the only time I've had a problem with the indirect system on my car was when I had a wheel that wasn't balanced very well (or it threw a weight  :-\) It was forever telling me to check tyre pressures when there was next to nothing between them & the system had been reset. Had the wheels/tyres rebalanced & that was it .... sorted! :y
No idea what the relationship between ABS sensors & unbalanced wheels could be  ??? ???
Don't get me started on lane departure avoidance. It's dangerous.
Also front collision warning which likes to apply the brakes every time a sharp bend is taken at more than 10 MPH. I can't switch this off so I have set it to spring into action as late as possible.
It's all nanny state crap.
Quote from: Andy B on 01 August 2023, 18:09:37
My car would give  a low pressure warning that could be made to go away if the car was driven for a mile or two. Presumably because the tyres became warmer.
Quote from: Andy B on 01 August 2023, 18:05:39
I have to remember to turn them off when I park at work. Otherwise, there's so much crap on the screen that they come on as soon as the ignition goes on, smearing detritus everywhere ;D
Rangie
I do check mine weekly & always have done since I started driving in 1971 , basic stuff really tyres oil screen wash etc.
Quote from: Rangie on 01 August 2023, 21:34:35.....
and do you regularly have to top your tyre pressures up? My tyre pressures rarely alter ....
.... and you've been driving not that much longer than me  ::)
Quote from: Field Marshal Dr. Opti on 01 August 2023, 18:43:10....
direct or indirect system?
Rangie
Quote from: Andy B on 01 August 2023, 22:13:21
Only very occasionally, one of the Subaru tyres has recently started losing about 3PSI over about a week but is due for a set of new tyres shortly, I won't change my habits of a lifetime though .
Quote from: Rangie on 01 August 2023, 22:48:03....
I never said you needed to .....  ::)
Pretty sure the indirect system is no longer allowed as it was shown to not give the intended warnings (I am told it never met the original regs).
Quote from: Andy B on 02 August 2023, 00:06:00
I expect old Mick is a bit stuck in his ways, so he could do.....  ???  :P  ;D
Quote from: Marks DTM Calib on 02 August 2023, 08:16:55...
so another money making plan ... £100 a corner pressure/temp sensor on each wheel!  :-\
the indirect on mine has high lighted a slow puncture
ronnyd
My fronts used to lose about 3psi over a couple of weeks, so had the rims cleaned when i had new Nexens fitted. Solved the problem, so had the rears done when the became due. £25 a corner as i seem to remember.
