vauxhall mokka tyre pressure fault
Started by raywilb, 29 July 2023, 17:45:45
raywilb
a mokka on a 16plate is telling me a tyre needs air, but it doesn,t . is there a sensor on the wheel that may be faulty, the tyres are recent all round
& in good nick.
Yep, there's definitely a sensor  ::)
Diesel till I die
ronnyd
Quote from: STEMO on 29 July 2023, 18:48:04
Nah, there's a little man, sorry, non gender person, running around with a tyre pressure gauge.
YZ250
#3
I assume that you've done the reset procedure.
Quote from: raywilb on 29 July 2023, 17:45:45
If you've carried out the reset procedure, maybe one of the TPMS sensors got damaged during the tyre change. Is it always the same wheel that shows under inflation.  :-\
Not sure on the Mokka.
Some systems have a sensor inside the tyre. Other systems use the ABS to detect the speed of rotation - if its ones of these, ensure the tyres are identical sizes.
It's the same as the astra, I think, sensor connected to the tyre valve.
Diesel till I die
raywilb
Quote from: YZ250 on 30 July 2023, 09:01:38
If you've carried out the reset procedure, maybe one of the TPMS sensors got damaged during the tyre change. Is it always the same wheel that shows under inflation.  :-\.
same tyre. reset procedure carried out does a new sensor need programming in once fitted ?
Rangie
So pleased I've none of these " helpful aids" on my cars, simply check them once a week with my antique Dunlop pressure gauge.
& in good nick.
is it telling you that a specific tyre is 'flat'? Or is it telling you that you that one of your tyres is 'flat'?
raywilb
Quote from: Andy B on 30 July 2023, 19:17:15
& in good nick.
the same corner needs air, tho as I said it doesnt , anyway its a job that requires the bead popping so its booked in to a tyre shop
Quote from: raywilb on 31 July 2023, 20:30:46
& in good nick.
but is the car telling you that you have a particular tyre that's flat ie direct system that has a pressure/temp sensor in each tyre & tells yo the pressure of individual tyres?
OR is it telling you that you need to go looking & one 1 of the 4 tyres is flat ie indirect that uses the ABS?
TPM is a pain in the arse.
The system in my old Jag would always show an error message when the weather was  very hot or very cold.
ronnyd
A lot of these 'driver aids' are just  to pander to drivers who are to idle to check their car once a week. I also know when it's raining ,because i see these funny wet spots all over the windscreen.  :D
Quote from: Field Marshal Dr. Opti on 01 August 2023, 14:24:26
Before I changed the battery, mine used to come on every time it went sideways.  With new battery, I only see it if the car has been left standing for a couple of weeks.
