vauxhall mokka tyre pressure fault
Started by raywilb, 29 July 2023, 17:45:45
Quote from: ronnyd on 02 August 2023, 19:21:52
Quote from: Rangie on 01 August 2023, 22:48:03
Quote from: Andy B on 01 August 2023, 22:13:21
Quote from: Rangie on 01 August 2023, 21:34:35.....
I do check mine weekly & always have done since I started driving in 1971 , basic stuff really tyres oil screen wash etc.
and do you regularly have to top your tyre pressures up? My tyre pressures rarely alter ....
.... and you've been driving not that much longer than me  ::)
Only very occasionally, one of the Subaru tyres has recently started losing about 3PSI over about a week but is due for a set of new tyres shortly, I won't change my habits of a lifetime though .
My fronts used to lose about 3psi over a couple of weeks, so had the rims cleaned when i had new Nexens fitted. Solved the problem, so had the rears done when the became due. £25 a corner as i seem to remember.
Yep.....elderly rims tend to become leaky with age......much like elderly people. ::) ::) :)
ronnyd
Quote from: Field Marshal Dr. Opti on 02 August 2023, 19:51:51
First hand experience then Opti.  ;)
Rangie
#32
Quote from: ronnyd on 01 August 2023, 15:11:39
A lot of these 'driver aids' are just  to pander to drivers who are to idle to check their car once a week. I also know when it's raining ,because i see these funny wet spots all over the windscreen.  :D
My sentiments entirely, I'd sooner trust my judgement after checking items rather than relying on some  "aid" that is prone to failure, and after 52 years I'm still doing fine..👍
Quote from: ronnyd on 02 August 2023, 23:36:07
I identify as 34....so no. :)
https://youtu.be/d6AnXi2N_do
Hey, Ronny. I've found the ideal car for you and STMO. :D ;D ;D ;D
Quote from: Rangie on 03 August 2023, 09:57:43
so what are you thoughts on ABS? Can you out brake your car's ABS ?  ::)
Of course. Even with a burger van on the back :D
Rangie
Quote from: Andy B on 03 August 2023, 12:22:10
Now you are getting silly , end of conversation.
My elderly rims were bent, which is why they leaked, but all good after I had them straightened out and refurbished!  :y
Rangie
Quote from: Field Marshal Dr. Opti on 01 August 2023, 18:43:10
Quote from: Andy B on 01 August 2023, 18:09:37
Quote from: Field Marshal Dr. Opti on 01 August 2023, 14:24:26
TPM is a pain in the arse.
The system in my old Jag would always show an error message when the weather was  very hot or very cold.
the only time I've had a problem with the indirect system on my car was when I had a wheel that wasn't balanced very well (or it threw a weight  :-\) It was forever telling me to check tyre pressures when there was next to nothing between them & the system had been reset. Had the wheels/tyres rebalanced & that was it .... sorted! :y
No idea what the relationship between ABS sensors & unbalanced wheels could be  ??? ???
My car would give  a low pressure warning that could be made to go away if the car was driven for a mile or two. Presumably because the tyres became warmer.
The only warning I've had in the Range Rover recently is low coolant level, however it's not low at all apparently it's a common fault with the float becoming inoperative after a few years so a  complete new coolant container is being fitted when it has its service next week.
We in general on here may not like TPMS but, the general public has turned into people who have zero idea about cars at all. Hence why TPMS is now a requirement to be fitted to all cars and why spare wheels are disappearing.
There were many serious accidents where cars with poorly inflated tyres were the cause, if you now splash it across the dash when this happens generally, (and there will always be a minority who don't) the car is stopped and checked.  :y
Sensor battery life is about 7-10 years typically (depends on use as they only wake up when the wheel moves) and the sensors are not stupid money like they used to be (and only require a generic tool to program them.....as this is also part of the requirements)
Rangie
Quote from: Marks DTM Calib on 08 August 2023, 10:45:50
A very sad state of affairs, also don't drink battery acid..😂
dave the builder
Quote from: Rangie on 08 August 2023, 10:48:18
:o
when did that come in  :-\
no one told me  :P
We get at least two breakdown calls a week where by the driver has pulled over because there is a warning on the instrument cluster for a low washer fluid level!
