Cadilac Catera 3.0 V6 is it worth to buy for fun or collection ?
Started by tomuxzz, 25 February 2024, 12:07:18
tomuxzz
HI,
I'm interested to buy this legendary model for weekends. Because I had Opel omega 10years ago and I really liked this model :D
For now its in good condition and everything works fine.
I want to ask maybe someone was selling this model?
What is the real market price in now days ? Or I shouldn't touch this model.. P.S I cant find any other such model in the market :(
If you're in Europe, then it's basically a rebadged Omega and should be treated as such.
If you're in the US and miss your Omega then yes, buy it.
ronnyd
Quote from: Doctor Gollum on 25 February 2024, 15:50:28
As his profile says Lithuania, if he waits a year or two he might manage a Zil.
Quote from: ronnyd on 25 February 2024, 16:33:54
People don't always change it when they move and I chose not to presume ;)
tomuxzz
But how about its value ? Its Cadillac..
I'm interested is it hard to sell in Europe Cadillac.
I also know that those engines do not have a good reputation, even though the car has only driven 130,000 km..
Quote from: tomuxzz on 25 February 2024, 17:43:28
As I said it's basically a rebadged Omega, built in Germany. in Europe it's value is the same as an Omega. And it will have exactly the same issues as an Omega... Because it's an Omega with a Cadillac badge.
Put it another way...  Would you pay more for a Vauxhall Astra than an Opel one?
tomuxzz
My question is not about if Cadillac is more worth than omega.
My main question is about this model (Vauxhall, Cadilacs, omegas) all together. Ok I will ask straight.  is it not too much to spend about 1500-2200 eur for this car in now days?
Quote from: Doctor Gollum on 25 February 2024, 18:45:11
johnnydog
Quote from: Doctor Gollum on 25 February 2024, 17:12:10
As he has only registered on OOF 3 days ago,  he is hardly likely to get his location wrong, and have moved in that time...... ::) ::)
Rangie
If you like the car & you can afford it without putting yourself into debt just go for it..👍
johnnydog
Quote from: tomuxzz on 26 February 2024, 08:34:04
It's the age old question - how much is an Omega or Cadillac worth?
There are a lot of factors involved to value one. I personally don't know how Cadillac Caterras are valued relative to Omegas, but assuming they are worth the same.... personally, I would go for a higher spec model (I would go for an Elite or the equivalent Caterra model), a V6 engine (personally a 3.0 3.2 above a 2.5 2.6)
And then condition plays a major part. Many now have corroded front chassis rails, corroded sill and rear wheel arches, plus other common Omega issues (which you can read about on this Forum), and with a model with notable corrosion issues, it depends if you are able to repair it and have the wish to repair a such a car. Some will say such a car is only worth £500 or less. But a well maintained, original top of the range model can command much higher figures than that. If you find a car for sale that is just that, the I don't think 1500 - 2000 euros is too high a price to pay for a good example requiring very little work , both bodily or mechanically. You may have to wait for sometime for the right car to come  up for sale, but finding the 'right' car is worth the wait.
You obviously like them, so once you've found the right one for you, it is basically worth what you are willing to pay.
In the long run, it is cheaper to pay a higher price for a car that needs very little doing to it, than paying a lower price for a car that needs body and mechanical repairs.
I'm not familiar with prices in Eastern Europe.  In the UK, it would have very low value, but it seems in most European countries the values are much higher.  Not quite sure why that is to be honest.
The engines are pretty good if serviced regular.  There are issues around cam cover gaskets failing every few years, and the oil cooler leaking on early models.
The Omega/Catera have a fair few other problems - rust, suspension being the main 2 I think - that kill them (if the owner can't be bothered to sort them), rather than the engine.
tomuxzz
Quote from: Rangie on 26 February 2024, 09:25:12
Great thanks. Yes without dept just for fun and collection :)
About cover gaskets I know situation.
I'm from eastern Europe. I registered in this forum because I liked that this is only Omega forum.
If that car would be rusty I will not buy it. I know this situation too :) Now that car was at the collector's garage and it has rich equipment.
Now I've found this information. Maybe someone heard more about this timing belt problem?
https://www.justanswer.com/gm/44e0b-97-catera-cadillac-recall-the-timing-belt-tensioner.html#:~:text=General%20Motors%20has%20decided%20that,and%20water%20pump%20may%20fail
The timing belt problem isn't a problem, and is eliminated by correctly fitting a new belt kit. That's a routine maintenance item, that should have already been done several times on a twenty plus year-old car.
Note the emphasis on correctly :y
Here in the UK, I suspect a Catera would be worth even less than a similar Omega due to it being left hand drive.
tomuxzz
Yes but mileage is low. So its interesting what belt is inside :D
About UK market I think the same.
Quote from: Nick W on 26 February 2024, 10:53:15
