Author Topic: washer non return valve  (Read 16129 times)
Re: washer non return valve
« Reply #15 on: 16 May 2025, 19:59:48 »
Is that better or worse than a shit part from China?  :-\     ;D
Talking of which have you tried Temu?  :D
I can confirm that pattern JLR headlamp washers from China are even worse than the JLR ones, though at £12, about a tenth of the price....
« Reply #16 on: 18 May 2025, 09:16:26 »
They only have to actually work once a year.. So far the original ones have managed that with a bit of fettling. ;D
.. although I then need to remember to remove the relay so it doesn't syphon out the contents of the washer bottle overnight.
« Reply #17 on: 18 May 2025, 10:08:42 »
"My" MOT tester has yet to test the headlamp washers on my ML. It's not that easy anyway cos they don't wash every time the screen is washed
« Reply #18 on: 18 May 2025, 15:45:22 »
There's a button on the light switch on the S... Not seen the Tester use it though... He has enough trouble finding the on/off switch for the ESP.
« Reply #19 on: 18 May 2025, 22:18:46 »
I got an advisory for them leaking last year, so maybe I'll try my luck with them inop next year and see.
« Reply #20 on: 19 May 2025, 13:49:40 »
I've had varied success with Mr Grumps, my normal MOTer.
As it happens, I find the headlight washers reasonably effective, so I try to keep them working over the winter months.
But the screen washer being shitty, that is a right royal PITFA.  I had to get out yesterday driving back from Luton with a cloth and a sprinkle of water, after dry-wiping the guts of an enormous fly, and embedding it into the glass in a perfect arc, right in my primary line of vision.
« Reply #21 on: 19 May 2025, 15:56:37 »
Other way round to my car, then. ::)
« Reply #22 on: 20 May 2025, 11:59:40 »
If yours is like her XE, that has a decent screen washer that chucks up a decent amount of water, and for as long as you press the button for.  Unlike the stupid XJ fanciful washer trying to be clever.
« Reply #23 on: 20 May 2025, 18:28:31 »
Yes, nothing wrong with the screen washer. The headlamp washers dribble a bit of water in the general direction of the headlamps when working, then syphon out the rest of the washer reservoir over the next couple of hours. >:(
« Reply #24 on: 21 May 2025, 09:53:02 »
I imagine a similar design to the XJ with those extending arms, although will be a different part number for maximum inconvenience, which could make them around £120 a pop for ones you get from a dealer (if your dealer's parts department can be bothered to deal with you), or around £15 from Ching Ching Chinaland.  Though believe it or not, the chinky ones are even lower quality!
« Reply #25 on: 21 May 2025, 11:16:39 »
On the XE, from memory, there is a valve with a spring in which should shut off the feed to the headlight  washers unless there is pump pressure (so its a check valve), its part of the T-piece part.
I know some have used a VW part to replace it with (281955187).
Maybe a good blow through with the air line might dislodge any crap or scale in there.
« Reply #26 on: 21 May 2025, 12:25:04 »
I'm guessing that part is too big for my XJ screen wash stuff - the T piece looks to be 5mm in, with 2 x 3.2mm out.
« Reply #27 on: 21 May 2025, 15:42:22 »
Ahh, that's useful to know. I was thinking about fitting something like this but if it already has one  I'll check it over.
