Heated Seat Conector in FL and others
Started by polilara, 07 November 2026, 04:41:33
polilara
Hello all
Car is 2001 FL havig five different power/temperature set points for seat heaters in dash. I changed front seats a couple of years ago as old seats were badly worn and I found used ones in very good condition. If I understood right they were from crashed low mileage car. Seat heaters worked fine in old seats but these new seats (both) do not heat at all. It was not a problem as I mainly use this car in summer time when towing but after having read this  https://www.omegaowners.com/forum/index.php?topic=152187.0
just wanted to know whether these new heaters could be wrong type. Connector was 100% similar so just clicked it there.
Were your replacement seats from a PFL/ML?  If so, you will not (easily) get the seats heaters to work in a FL, as the FL have a heating controller embedded in the seat base cushion, rather than the connector being wired directly to the elements as in MFL/PFL.
polilara
#2
Thanks,TB, actually I do not know what model it was except, Silver Grey..., that's rear, the car ended around A-pillar. But the connnector fits well and that was my original question; are they all similar to each other despite of model ? I have schemas so I can modify wiring if that's it.  Nice outlook of new pages!
I believe most of the connectors between MFL and FL are the same around seats.
However, if you have fitted MFL seats, you will have to rewire the car to be a simple ON/OFF power to the elements (or dig out a seating controller from an old FL seat - tiny thing about size of 2 dice - and wire it in externally)
polilara
Ok, thanks TB, strange situation if connectors are similar, I think. I have original seats left, have to check amount of wires of both etc.
Might be best to look for any date stamps (such as in the plastic mouldings) to ascertain if they are pre or post 2000, as that would be a reasonable, but not foolproof, clue.
