rolling road graph
Started by tyreburner, 08 January 2007, 18:08:28
tyreburner
just been having a proper look through the bumph that i got with me car , and have found a rolling road graph from last owner showing
max power  206BHP@5973 rpm  [smiley=2vrolijk_08.gif]
max torque  194lbft@5173rpm   [smiley=2vrolijk_08.gif]
all i am aware of maggie havin done is a courtney panel filter and a powerflow back box
is this any good she has done 176000 miles and is a 1996 car??
I am quite impressed as i believe this is very close to the power when new?
Mick
"well at least I'm lucky I don't have all the power in the world so I can't opps everything else up."
Quotejust been having a proper look through the bumph that i got with me car , and have found a rolling road graph from last owner showing
Mick
Similar to factory quoted figures.  Though it is said that the factory figures are pessimistic.
Even so, good figures :y
Phil
Add and M-Tek chip like me and those smiles will be even bigger  ;D
tyreburner
are they any good as have been offered one foc from the guy who had the car b4 the guy i got it off?
are they hard to fit?
Cheers
Mick
Quoteare they any good as have been offered one foc from the guy who had the car b4 the guy i got it off?
Cheers
Mick
Depends what kind of chip it is if its any good....
tyreburner
all i know is its an m-tek one??
by the way the 20 times start of the car has cleared fault codes from ecu
cheers for the advice
will take it work in morning and see what codes i get
Mick
Phil
Proven 228bhp on a car that has done 124k ish, and is in need of a good service, and thats without using any high octane fuel (optimax or similar), so i would say not bad  ;D
And before the 'all rolling roads are different' arguements start on the same day an Astra coupe and a VX220, both standard 2.2s, returned figures with 1 bhp of book, and an Astra VXR came in at +2bhp over book
tyreburner
how about ease of fitment , bearing in mind i tried to change a switch bulb and ended up melting the blue plastic and solder into one yukky mess [smiley=huh.gif]??
tyreburner
heres the graph . dont know what any of it means maybe you guys can de cypher it?
if theres anything to see?
as i have said before i have always been a one for buy it drive it break it fix it and make it worse then sell it so this is new to me ::)
mick
Tina
Quoteall i know is its an m-tek one??
HOW MUCH BHP WITH IT   :o
Its soooooo nice to know i have the best of both worlds.
and michael you can borrow Hector ANYTIME you want for work and the shop  ::)  :-*
My beast will be back with me soon :)
Quattro & Ummpphh what more can a girl want
Admin
Tyreburner, and Tina.
I can recommend the Mtek chip, nice upgrade, and I will be fitting another one (or 2) very shortly to the current Omegas.
Definite improvement in power, and no loss on the economy side either. :)
The Administrator.
Interesting....I suspect the multiram is not fully functional at the moment as the low end grunt is quite down.
Big Rod
It's almost a carbon copy of the readout from my old Senator when the DR wasn't working properly. The sharp hike when the butterfly opens looks like a fault with the valves
If I have to explain you won't understand!
tyreburner
uh lost me .. i think dr means dual ram how /what do i have to check to find out why she aint as fast as she should be lol
Blip the engine whilst looking at the front and then the rear multiram vac actuators (see maintenance section for more multiram info) and check they are moving and free (they should move quite quickly)
