Pages: 1 [2] 3  All   Go Down
Author Topic: Vauxhall NIL   me  1.... TC/ABS  (Read 7700 times)
MartinP
  • Dudley
    • BMW 320D
Re: Vauxhall NIL   me  1.... TC/ABS
« Reply #15 on: 14 January 2007, 20:51:11 »
Any chance of getting hold of the failed one so I can strip it and try to determine themode of failure....
Definitely, I was going to offer it to TB to see if he could gleam anything from it.
It would only go in the bin otherwise.
MartinP
  • Dudley
    • BMW 320D
« Reply #16 on: 14 January 2007, 20:52:44 »
So, jobs for TB;
reprogram TC
reprogram gearbox (if poss)
Can't remember what we decided about your g/box being programmable?
Maybe / maybe not
when we get together we can see.
« Reply #17 on: 14 January 2007, 21:07:27 »
Give it to Mark_DTM to diagnose ;)
Mark - relays may stick ;)
Matchless
  • Nottingham
    • A white van
« Reply #18 on: 14 January 2007, 22:15:57 »
Breaking News......
Issunaz fails MoT due to 2 missing bolts.
Only joking. How long before the cuts and grazes heal?
MartinP
  • Dudley
    • BMW 320D
« Reply #19 on: 15 January 2007, 17:47:00 »
Breaking News......
 Do you really think that an MOT bod will find the holes????  :)
Only drew blood once  :'(
« Last Edit: 15 January 2007, 17:47:58 by issunaz »
Rob Davidson
« Reply #20 on: 23 December 2008, 20:11:56 »
After reading this thread, I decided to give it a go on the wifes 1999 2.5 GLS Auto , as it has had the TC / ABS lights and no speedo for a few months and the MOT was due.
Went to my local breakers and had a look round there Omegas, for the closest match to mine, found a 2.5 manual Saloon on a V plate, they only had a 2.0 auto estate, I thought the this would be the closest match.
The breakers charged me £20 for the ABS control Unit
Managed to strip the only out the donor Omega in about 30 minutes, there was already a few bits missing under the bonnet when I started.
Anyway to cut a long story short, i followed the instructions on here, and fitted the new one, could only get 4 of the 6 screws back in.
Took about a hour to fit in, I topped the power steering fluid back up, and decided to turn the key and see if all my hard work and scratched arms had had been worth it.
started the engine, both lights went out!, took it for a test drive, speedo worked, tested the ABS and TC all working fine, problem solved. I didn't have the car or ABS unit reprogrammed or anything.
Took it for a MOT and it passed!
I did this back in the summer, meant to post my results sooner, but only just got round to it!
I think the problem was caused by oil leaking from Cam covers onto the ABS unit, the electrics had oil on them when I had a look.
Anyway, the Omega died last month, and has now joined its Brothers in the same scrap yard as I got the ABS unit from .
Thanks guys for posting your experiences on here, it gave me the courage to attempt this.
Just got the wife another Omega, a 2.5 Auto CDX on a S plate this time, far better car then the one before
STMO123
« Reply #21 on: 23 December 2008, 20:19:39 »
Great results. Well done :y
« Reply #22 on: 23 December 2008, 20:48:10 »
And if your any good with a soldering iron.....you can repair it!
« Reply #23 on: 23 December 2008, 20:53:07 »
Pictures??? ;D :y
STMO123
« Reply #24 on: 23 December 2008, 20:57:04 »
Doesn't seem necessary if you can interchange the units for scrap ones.
Unless, of course, you really enjoy taking things to bits and fiddling with them for hours to see if you can make them work.
But no one would be bothered, would they? :D
« Reply #25 on: 23 December 2008, 21:00:25 »
I don't know!?! Our dining room table disappeared under the varous bits that made up my sister-in-law's hall light last night.  :-?I was determined to fix the bugger.
I won in the end!!!  ;D  ;D  ;D  :y
I always get a feeling of satisfaction when I fix something.
Taxi_Driver
« Reply #26 on: 23 December 2008, 21:08:44 »
Is that an invite to fix mine for me  ;) ;D
STMO123
« Reply #27 on: 23 December 2008, 21:15:22 »
Ah...sarcasm,irony....just two of the things that are lost on Andy.
Nickffc
  • Terrington St Clement, Norfolk
« Reply #28 on: 15 January 2009, 15:44:52 »
hmm. so you replaced a :
0265220427 abs ecu
with a :
0273004206 abs ecu..
and it worked???
i have the same problem...
V reg MV6  No TC ABS or speedo....
still trying to find a replacement ecu....!
Nick
« Last Edit: 15 January 2009, 15:45:06 by Nickffc »
DRIVE IT LIKE YOU STOLE IT......!!!!
3.0 MV6 Estate
1.9dti Astravan sportive
« Reply #29 on: 15 January 2009, 15:52:16 »
PM Elite Pete or Loo Knee....I know they have two (one from a 3.0 and one from a 2.5)
Pages: 1 [2] 3  All   Go Up
