Pages: [1] 2 3  All   Go Down
Author Topic: Vauxhall NIL   me  1.... TC/ABS  (Read 7707 times)
MartinP
  • Dudley
    • BMW 320D
« on: 13 January 2007, 23:58:57 »
After reading a thread on here where an ABS module was changed over, I started looking at mine as I have had no speedo, TC or ABS for most of this year.
and the MOT is due in a fortnight  :o
My ABS unit is as follows;
3.0 MV6 98R
Main body marked as DX
0265220427
9127952
Bosch unit marked 771559
0273004206
2.5 V6 98R
Spare ABS unit marked as DJ
0265220427
90538656
Bosch ABS unit marked 762543
0273004206
removed the battery, 3 multiplugs and base unit next to the battery and the top radiator hose.
Drew a deep breath and started to remove the 6 screws holding the Bosch unit on, was tricky but got there in about 30 mins, swapped teh unit over and put 4  :-[ screws back in (didn't put the hard ones in as I may have had to take them out again).
re-assembled, topped up the water, refitted the battery and turned the key.
THE TC AND ABS LIGHTS ONLY WENT OFF  :o 8-) ::) :y :y :)
re-checked all the connections and went for a test drive.
I now have a working speedo, tripp counter, functioning ABS (tested) and TC (tested)
I am a happy bunny
« Last Edit: 13 January 2007, 23:59:47 by issunaz »
Chopsdad
  • Bouncy Castle in Carlisle
  • Keep it clean!
Re: Vauxhall NIL   me  1.... TC/ABS
« Reply #1 on: 14 January 2007, 00:01:00 »
You have been a busy bunny  ;)
« Reply #2 on: 14 January 2007, 06:48:38 »
3.0 MV6 98R
0265220427
9127952
0273004206
2.5 V6 98R
0265220427
90538656
0273004206
I am a happy bunny
Good man. Fancy writing a How2?
« Reply #3 on: 14 January 2007, 09:01:40 »
Get it on a tech2 now.
Your TC is programmed for a 2.5 not 3.0, 1 minute to reprogram to correct car.
Well done on the job though!
Markjay
  • London
« Reply #4 on: 14 January 2007, 09:49:48 »
Well done! any pictures, per chance...?
Alas, no more Omegas....
« Reply #5 on: 14 January 2007, 11:06:00 »
3.0 MV6 98R
0265220427
9127952
0273004206
2.5 V6 98R
0265220427
90538656
0273004206
I am a happy bunny
You may need variant reprogrammed as set for wrong engine. Tech2 I'm afraid.
jonny2112
  • Bangor NI
    • 2.6 Elite
« Reply #6 on: 14 January 2007, 16:03:33 »
Great job, and a happy ending too  :y
MartinP
  • Dudley
    • BMW 320D
« Reply #7 on: 14 January 2007, 20:02:52 »
 There was a general description of how to, on here already, I just followed that.
I wasn't on long enough last night to find it and "doff the cap".
(SWMBO was moaning, "you've either been up the garage or on the computer, why don't you sit with me and watch the tele")
MartinP
  • Dudley
    • BMW 320D
« Reply #8 on: 14 January 2007, 20:05:36 »
I have tried to include as much info on the units so that if anybody else want's to give it a go they can compare.
« Reply #9 on: 14 January 2007, 20:26:49 »
Well done m8 :y aren't you lucky
MartinP
  • Dudley
    • BMW 320D
« Reply #10 on: 14 January 2007, 20:30:57 »
OK found the HOW TO... in the "Maintenance Guides"
Author Steve_W
I didn't remove
-Engine relay/ ECU box
-Coolant transfer pipe (thermostat feed pipe) (for clearance)
-Top plenum (optional but easier to locate the transfer pipe properly with it off)
-PAS pipe from top of pump for clearance
-PAS reservoir (ideally but can be moved out of the way, but will stretch pipes.) moved it out of the way & tied it up
it was fiddly but can be done with patience  ;)
MartinP
  • Dudley
    • BMW 320D
« Reply #11 on: 14 January 2007, 20:35:23 »
So, jobs for TB;
reprogram TC
reprogram gearbox (if poss)
« Reply #12 on: 14 January 2007, 20:41:41 »
So, jobs for TB;
reprogram TC
Can't remember what we decided about your g/box being programmable?
« Reply #13 on: 14 January 2007, 20:42:00 »
Any chance of getting hold of the failed one so I can strip it and try to determine themode of failure....
MartinP
  • Dudley
    • BMW 320D
« Reply #14 on: 14 January 2007, 20:49:16 »
If you can imagine... a picture of two oil covered forearms dissappearing into the engine bay as though they had handcuffs on, a thoughtful and sometimes quizzical expression on my face.  :)
 I don't think any other picture would help really.  ;D
Pages: [1] 2 3  All   Go Up
