Pages: 1 2 [3]  All   Go Down
Author Topic: Vauxhall NIL   me  1.... TC/ABS  (Read 7706 times)
oceansoul
  • Sunbury on Thames - Surrey
Re: Vauxhall NIL   me  1.... TC/ABS
« Reply #30 on: 15 January 2009, 17:42:12 »
After reading this thread, I decided to give it a go on the wifes 1999 2.5 GLS Auto , as it has had the TC / ABS lights and no speedo for a few months and the MOT was due.
Went to my local breakers and had a look round there Omegas, for the closest match to mine, found a 2.5 manual Saloon on a V plate, they only had a 2.0 auto estate, I thought the this would be the closest match.
The breakers charged me £20 for the ABS control Unit
Managed to strip the only out the donor Omega in about 30 minutes, there was already a few bits missing under the bonnet when I started.
Anyway to cut a long story short, i followed the instructions on here, and fitted the new one, could only get 4 of the 6 screws back in.
Took about a hour to fit in, I topped the power steering fluid back up, and decided to turn the key and see if all my hard work and scratched arms had had been worth it.
started the engine, both lights went out!, took it for a test drive, speedo worked, tested the ABS and TC all working fine, problem solved. I didn't have the car or ABS unit reprogrammed or anything.
Took it for a MOT and it passed!
I did this back in the summer, meant to post my results sooner, but only just got round to it!
I think the problem was caused by oil leaking from Cam covers onto the ABS unit, the electrics had oil on them when I had a look.
Anyway, the Omega died last month, and has now joined its Brothers in the same scrap yard as I got the ABS unit from .
Thanks guys for posting your experiences on here, it gave me the courage to attempt this.
Just got the wife another Omega, a 2.5 Auto CDX on a S plate this time, far better car then the one before
I thought that the 2.0 (2.2) ecu wasnt and couldnt be programmed with TC.....so how could this operate the TC in a 2.5(2.6) or 3.0(3.2) ???
Nickffc
  • Terrington St Clement, Norfolk
« Reply #31 on: 19 January 2009, 22:15:27 »
cheers.....
Nick
DRIVE IT LIKE YOU STOLE IT......!!!!
3.0 MV6 Estate
1.9dti Astravan sportive
« Reply #32 on: 19 January 2009, 23:50:07 »
hmm. so you replaced a :
0265220427 abs ecu
with a :
0273004206 abs ecu..
and it worked???
i have the same problem...
V reg MV6  No TC ABS or speedo....
still trying to find a replacement ecu....!
Nick
No he replaced a 0273004206 abs ecu with another 0273004206 abs ecu.  The 0265220427 number is the nş on the abs module.
Pages: 1 2 [3]  All   Go Up
