Author Topic: Cheap Mono Laser printer  (Read 1217 times)
« on: 05 March 2009, 20:48:02 »
Need to buy a cheap mono laser.
Anyone got any recommendations / avoids?
poss the HP p1005 or samsung ML2240
the very base of the market ones.
Cheers
Re: Cheap Mono Laser printer
« Reply #1 on: 05 March 2009, 20:49:23 »
I can thoroughly recommend the strength of the old Laserjet 4000, alas cannot recommend its ability to print, hence able to comment on the printer's strength ::)
« Reply #2 on: 05 March 2009, 20:55:04 »
Cheers
There's a HP Laserjet IIIp here you have have FOC if you want it. It needs a toner(£££££'s), but it did work OK when last used ..... ages back.
« Reply #3 on: 05 March 2009, 20:57:59 »
laserjet 3, havent used one of those for a while!
cheers for the offer, but its not for me, and needs to be a shiny new one ;)
Ive a cracking lexmark optra s here  ::)
« Reply #4 on: 05 March 2009, 21:04:22 »
I bought a xerox for £99 years ago and still doing ok on original toner cartridge.  Certainly not overworked though, but never an isue when it's called upon.
« Last Edit: 05 March 2009, 21:05:08 by skruntie »
« Reply #5 on: 05 March 2009, 21:06:21 »
neither have I  ;D
Sad
  • Dorset
    • VW Golf
« Reply #6 on: 05 March 2009, 21:12:38 »
I'd recommend the Samsung.  Got a ML-4500 (I think) about 6 years ago from fleaBay, was brilliant.  Just don't leave it in a loft for 18months and expect it to work when you plug it in again    ::)
« Reply #7 on: 05 March 2009, 21:17:23 »
The advantage of the common makes, such a gayHP and Lexmarks, is you can always get an emergency cartridge from your local Staples etc.
« Reply #8 on: 05 March 2009, 21:38:26 »
Thats 1/2 the reason for a laser - the user is unlikely to ever need another cartridge, and no worry of dried up ink either  :y
« Reply #9 on: 05 March 2009, 21:40:33 »
with age, the cleaning brushes that clean drum may go hard, resulting in a new cartridge to improve print quality
immx
  • Essex
« Reply #10 on: 05 March 2009, 21:48:48 »
I have to print around 30-50 pages a day for work and Ive got a Canon LBP2900i
It was £69.99 from PC World about 2 years ago and has never let me down (touch wood!)  Cartridges are £35 from tesco direct.
« Reply #11 on: 05 March 2009, 21:51:39 »
samsung ML2240 is a good laser ..father using it.. and I'm using
the previous model with scanner.. no problems so far..
Martin_1962
« Reply #12 on: 05 March 2009, 22:00:03 »
Our work Laserjet 3 still works fine.
They had a LJIII when I started there around 16 years ago
