Author Topic: Pedal Trick?  (Read 1436 times)
ScottieMV6
  • Swinton, Manchester
Pedal Trick?
« on: 24 March 2009, 17:38:05 »
Should the pedal trick work on all cars? Is it auto only or manual as well. Just tried it on my 1998 MV6 manual and can't get it to work.
I can't even see which light should flash. Watched the video but the light that is flashing in the video seems to be different to mine. Mine looks like a towbar??? :-[
I'd rather be scared to death than bored to death!!
Re: Pedal Trick?
« Reply #1 on: 24 March 2009, 17:41:30 »
No, paperclip for you, pedal only works on 2.6 and 3.2
Re: Pedal Trick?
« Reply #2 on: 24 March 2009, 17:42:07 »
Hi Scott
The pedal trick only works on the drive by wire cars ie later Facelift.
ScottieMV6
Re: Pedal Trick?
« Reply #3 on: 24 March 2009, 17:51:51 »
Thanks guys.
I have done paperclip test and no codes. Just seems to be running a bit rough especially just after start up and is making a strange whistling sound when accelerating?
Any ideas?
Re: Pedal Trick?
« Reply #4 on: 24 March 2009, 17:56:42 »
Sounds like you have an airleak if its whistling
ScottieMV6
Re: Pedal Trick?
« Reply #5 on: 24 March 2009, 17:59:01 »
Thats what I thought but no idea where its coming from. Any places favourite? Its only done it since I put it back together after cam belt and cam cover gasket change.
Am I going to have to strip down the plenum etc??? :(
Re: Pedal Trick?
« Reply #6 on: 24 March 2009, 18:44:11 »
Get the engine idling then spray carb cleaner around the plenum area and vac hoses. Any change in the engine, you`ve found an air leak ;)
« Last Edit: 24 March 2009, 18:51:21 by RobG »
ScottieMV6
Re: Pedal Trick?
« Reply #7 on: 24 March 2009, 18:52:35 »
Thanks Rob. I'll try that tomorrow  :y
Pitchfork
  • Tadley (near Basingrad)
  • Barndances & Morris
Re: Pedal Trick?
« Reply #8 on: 25 March 2009, 13:19:26 »
Could just be happy! :) :)
