Author Topic: Please help.........Astra MOT Emissions failure  (Read 2093 times)
webby23
  • Nottingham
  • MV6
« on: 04 April 2009, 01:21:28 »
My sister took her W reg Astra in for an MOT yesterday (Friday) but sadly it failed on Emissions.
Any ideas what could be wrong with it based on the results given below?
Many thanks in advance for any advice given.
Martyn
                                               Limits              Actual Values             Results
Engine Oil Temp                       Temp gauge shown warm
1st fast idle test
Engine RPM                             2750/3250       Manual check               Not tested
CO% Vol                                 0.30                 0.54                             Failed
HC ppm Vol                            200                  133                              Pass
Lampda                                    0.91/1.03         0.99                             Pass
2nd fast idle test
Engine RPM                             2570/3250       Manual Check              Not tested
CO% Vol                                 0.30                 0.28                             Pass
HC ppm Vol                            200                  119                              Pass
Lamdpa                                    0.97/1.03         0.99                             Pass
Natural Idle test
Engine RPM                             730/990           Manual Check              Not tested
CO% Vol                                 0.50                 0.67                             Fail
Overall results        Test Failed
Ian_D
  • York
Re: Please help.........Astra MOT Emissions failure
« Reply #1 on: 04 April 2009, 02:33:03 »
What type of driving does your sister do? Small local trips to shops?
If so, I would take it out for a good long thrashing! This should warm the CAT right up, which often bring them back to life!
Other than that, give it a service (Oil + Air Filter, and maybe Spark Plugs depending on age / condition).
Also check for any airleaks / exhaust leaks as this can/will effect emissions!
HTH
[size=12]
webby23
  • Nottingham
  • MV6
« Reply #2 on: 04 April 2009, 02:44:36 »
Mostly tootling around I think mate, definately doesnt rag it about......
To my untrained eye just looks like the CO is too high.......Does that just mean that the filters could be dirty?
Will find out later on when was its last service if i can
Thanks
« Last Edit: 04 April 2009, 02:45:33 by webby23 »
« Reply #3 on: 04 April 2009, 07:31:48 »
Isit getting upto temp.....could be stat stuck open.
Is she local, can do a quick T2 session on it for her.
dad1uk
  • Birmingham
    • Vauxhall Zafira 2.2
« Reply #4 on: 04 April 2009, 07:46:29 »
The CO2 is not that far out, I always add a petrol addative about a week before the test and change the oil and filter and air filter, and give it a thrashing up the motorway the day or the day before the test.
If the car has just pootled about town, then a thrashing could well sort your problem.
Good luck!
best wishes
Simon.
webby23
  • Nottingham
  • MV6
« Reply #5 on: 04 April 2009, 08:37:09 »
She did say that the tester reckoned it was "running rough" and rich
Temp showing on test result as warm, but trying to contact her now and her blinking phone is off
Shes in Leicester Mark
Not sure if it is allowed on the road though failing its mot before the old one ran out?
« Last Edit: 04 April 2009, 08:46:29 by webby23 »
webby23
  • Nottingham
  • MV6
« Reply #6 on: 04 April 2009, 08:48:49 »
from her email last night
"Attached is a copy of the emissions test. The tester also said that the engine sounds like "its running rough" and "running rich" due to the amount of unburnt fuel coming through the exhaust emissions"
« Reply #7 on: 04 April 2009, 09:22:07 »
Its MOT'd until the date of the last certificate....so its still covered.
Christian
  • Shropshire
« Reply #8 on: 04 April 2009, 09:39:40 »
Looking at it ide say Oxygen sensor?
Nope i dont doo Sheep!
« Reply #9 on: 04 April 2009, 09:42:49 »
Nah.....hardly ever is.
I would guess coil pack failing or stat stuck open
HGV mechanic
  • northamptonshire
  • he just keeps on going,,,
« Reply #10 on: 04 April 2009, 10:00:32 »
i would try,, cleaning throttle body, and evap system , also blow out/change air fitler  /check MAF sensor and genrally a good service with some redex and a good drive
wouldnt think it would be stat as it passed 2nd fast idel
« Reply #11 on: 04 April 2009, 10:04:15 »
Barely....after having a good long rev.
Its one to check, T2 will also allow us to see what temp the instruments and ECU think the water is  :y
webby23
  • Nottingham
  • MV6
« Reply #12 on: 04 April 2009, 10:07:41 »
The car was allegedly fully serviced a couple of weeks ago so will be expecting to see new sparkies and filters in it when the brother in law brings it up here tomrw
HGV mechanic
  • northamptonshire
« Reply #13 on: 04 April 2009, 10:11:41 »
let us know :)
