Pages: [1] 2 3  All   Go Down
Author Topic: Vectra Brakes  (Read 3066 times)
Vectra Brakes
« on: 02 April 2009, 18:44:24 »
Vectra Brakes were down to the metal.
New disks and pads fitted,
pedal spongey.
Bled brakes, got some manky old fluid out, and some air bubbles.
Pedal is still spongey, you can pump the pedal up each time you get in the car, and once brakes pressed, pedal does sink further.
Any ideas anyone?
Cheers
Re: Vectra Brakes
« Reply #1 on: 02 April 2009, 18:45:31 »
Did you let the fluid out the bleed nipple when you pressed the pistons back in?
Re: Vectra Brakes
« Reply #2 on: 02 April 2009, 18:48:47 »
No,  :-/
Re: Vectra Brakes
« Reply #3 on: 02 April 2009, 18:52:13 »
No,  :-/
Ow dear.....ow dear ow dear......ow dear ow dear ow dear ow dear......
Right, get in the car and press teh brake pedal righ down, as you lift your foot off get somebody to hit the end of the brake master cylinder with a mall....oh yes,ok, lets start again.
Get Ljay to press the brake pedal all the way down and as she quickly lifts her foot off hit the end of the brake master cylinder with a mallet..
I asume the padswere fitted correctly?
Rubber backed pad sections against the caliper frame and metal to the caliper piston?
All sliders are free?
Re: Vectra Brakes
« Reply #4 on: 02 April 2009, 18:55:09 »
No,  :-/
Father in law and me this one.
Different set up to the omega, you can't get em the wrong way round, clips go into the piston, and bloody 7mm allen key to secure calliper
What set has 7mm?  6 - 8 everywhere  >:(
Is this the inverted seal I've heard mention of?
Re: Vectra Brakes
« Reply #5 on: 02 April 2009, 18:56:51 »
What sort of strength hit?
Re: Vectra Brakes
« Reply #6 on: 02 April 2009, 19:01:58 »
Mine has 7mm....only shite Halfords sets have key sizes missing
Re: Vectra Brakes
« Reply #7 on: 02 April 2009, 19:02:21 »
Like your hitting a chisel....repeat it 5 or 6 times
Ian_D
  • York
Re: Vectra Brakes
« Reply #8 on: 02 April 2009, 19:03:39 »
No,  :-/
What actually happens? Does it flip the seals or something?  :-?
[size=12]
Re: Vectra Brakes
« Reply #9 on: 02 April 2009, 19:03:54 »
ok, is that 5-6 times hit per pedal release, or whole procedure 5-6 times?
Re: Vectra Brakes
« Reply #10 on: 02 April 2009, 19:04:22 »
Whole procedure 5-6times
Re: Vectra Brakes
« Reply #11 on: 02 April 2009, 19:04:36 »
No,  :-/
It certainly can
Re: Vectra Brakes
« Reply #12 on: 02 April 2009, 19:07:06 »
MkIII Escort  :y That's why I have one, biught for my brother's car years ago. ;) ;)
Re: Vectra Brakes
« Reply #13 on: 02 April 2009, 19:10:18 »
pedal spongey. ....
I think this is what I'll have to do eventually on my Omega.
Ian_D
  • York
Re: Vectra Brakes
« Reply #14 on: 02 April 2009, 19:11:31 »
No,  :-/
It certainly can
Thought I read about it somewhere years ago!
Which seals does it flip? ABS pump or Master Cylinder? Im assuming Master Cylinder since your suggesting hitting it! Hows that fix it then? (Just been nosey!  ;D)
[size=12]
Pages: [1] 2 3  All   Go Up
