Author Topic: nearly kicked out of vx!  (Read 2170 times)
unlucky alf
  • worksop, notts
Re: nearly kicked out of vx!
« Reply #15 on: 07 April 2009, 22:54:19 »
yup i got the 2 rubber ones [one tiny for bolt end & other for canister cap] & 2 copper ones, one of the copper ones goes on the bolt head which is fine but the other doesnt fit the sump plug ive got, i can only assume that the sump has been played with even though it doesnt look like anything has been done to it, the copper washer that came off is 25mm [1"] across & the hole is approx 18mm bore, does that help identify it at all :-/
Richie London
  • heathrow
« Reply #16 on: 07 April 2009, 23:23:27 »
the one ive got is about 18mm dia, it maybe for the autobox plug
unlucky alf
  • worksop, notts
« Reply #17 on: 07 April 2009, 23:37:06 »
its not a g/box one ritchie as ive met them a few times!,the nearest thing i can find is on fleabay but listed as various landrover models,[perhaps a tad wider on O/D] now i know landrover used the same bmw 2.5 engine so perhaps theyll do the job :-/
platty
  • Cambridge
    • BMW 530d Sport
« Reply #18 on: 08 April 2009, 13:17:11 »
In the Vx oil filters they always supply a copper washer (along with the rubber o-rings for the filter cap) but my sump plug needs a T8/10 to remove and has a o-ring bonded to it so I have never changed it.
Can replacement sump plugs be bought? I seem to remember Vx not having a clue when I asked them...
ians
  • Reading
« Reply #19 on: 08 April 2009, 14:40:48 »
The oring is not bonded to it (well it wasn't originally..) and is replaceable.
Sump plugs are available too.
I've never received a copper washer with an oil filter of either type.. :-?
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
« Reply #20 on: 08 April 2009, 15:02:17 »
I thought the o ring was part of the plug.....think it was on my 2.2, rubber part, with a magnet on the end of the oil end of the plug. Maybe that was on later omega's  :-/ :-/
Always bought the 'O' ring separately, never had a problem, but then I usually buy 10 at a time.
I like red cars
ians
  • Reading
« Reply #21 on: 08 April 2009, 15:26:40 »
I've usually bought them 1 for one with filters which I tend to buy 5 of at a time. Never a problem.  Can dig out the part number if need be.  I would certainly change it every other oil change.
platty
  • Cambridge
    • BMW 530d Sport
« Reply #22 on: 08 April 2009, 17:23:48 »
Mine has probably lasted about 5 oil changes now, and I haven't got around to changing it yet - I have got an O ring set at home so I might just match it up if I can pop it out, never tried before.
unlucky alf
  • worksop, notts
« Reply #23 on: 08 April 2009, 18:43:29 »
id be interested to know if your sump plug is the same as mine being a similar year,on mine the copper o ring is a tight fit onto the plug itself & is of the crushable type, the plug itself is a 17mm hex head one, does this sound standard??
« Reply #24 on: 08 April 2009, 19:18:21 »
pattern fiilter, of GM? GM TD filters always come with the rubber seals for the filter and the copper washer(s) for sump
