Author Topic: nearly kicked out of vx!  (Read 2182 times)
unlucky alf
  • worksop, notts
« on: 07 April 2009, 17:41:35 »
i went to my local stealer yesterday to get a sump plug seal/ring, he was gone for a while & came back with one, i told him it didnt look right to me but he said they dont have a number for the ring only for sump plug with ring, so he gave me the o ring on its own [well 20p for it], anyhow started to do oil & filter change today & guess what,,,,,yup it was the wrong o ring, so back to vx i go in my other halfs car & told them again what i needed, he was gone ages then came back with a seal for a 1.9 [or so he said], totally different thing altogether, its like a washer with a rubber ring bonded into the hole, he says "thatll do ya mate" so i explained that is was somewhat a "prick in a bucket" fit, i was then told if i wanted the correct one i would have to buy 20!!, so not happy with that i said "so if i came in for a service youd bodge my motor with anything that came to hand" >:(, with that he got a bit stroppy & slapped this thing he came up with plus another rubber ring & walked off!, so ive had to use the 1.9 thing he gave me as i was stuffed otherwise, it is holding as far as i can see at the mo but this proves what everyone says that going to vx for a service could be a dangerous thing & not to be advised >:( >:(
nick v6
  • walsall / west midlands
Re: nearly kicked out of vx!
« Reply #1 on: 07 April 2009, 17:48:05 »
what a t**t
customer is always right
miggy
« Reply #2 on: 07 April 2009, 17:50:12 »
Sounds like he was one
Taxi_Driver
« Reply #3 on: 07 April 2009, 18:44:49 »
I thought the o ring was part of the plug.....think it was on my 2.2, rubber part, with a magnet on the end of the oil end of the plug. Maybe that was on later omega's  :-/ :-/
unlucky alf
  • worksop, notts
« Reply #4 on: 07 April 2009, 18:50:40 »
mine is an old 2.5 td that i believe has a crushable o ring i think they call it ;)
waspy
« Reply #5 on: 07 April 2009, 18:56:18 »
Measure the size of your plug threads for me. We have the very same rings at work for the hydro hoses i fit. I'll post you some :y
Chris_H
  • E London/Essex UK
    • Jag XF Portfolio S 3.0D
« Reply #6 on: 07 April 2009, 18:57:01 »
what a t**t
I'm afraid that's been long superseded.  The customer is now a cow to be milked according to current best business practice. :'(
Ask your utility company if in doubt.
First Vauxhall - PABX Cresta; Previous, previous Vauxhall - 3.0 12v Senator CD; Previous Vauxhall Omega Elite 3.0V6 Saloon Auto
« Reply #7 on: 07 April 2009, 19:07:03 »
std copper washer, comes as part of the oil filter ;)
« Reply #8 on: 07 April 2009, 19:08:00 »
And I have a bucketload here, as my tractor had a different sumplug (due to helicoil)
Good job they fit the zx10, and the rover ;D
« Last Edit: 07 April 2009, 19:08:32 by TheBoy »
waspy
« Reply #9 on: 07 April 2009, 19:24:49 »
Silly me. You've fitted the plug & of course you don't want to remove it :-[
Well if you remember to give it measure next time you remove it & PM me & i'll sort some for you :)
Turk
  • Llanelli, Wales
    • 2.5td, H-D XL1200
« Reply #10 on: 07 April 2009, 20:10:47 »
what a t**t
The way I look at it is, the customer isn't always right...but he/she is always the customer, and without customers...you don't have a business.
The Barge Captain
« Reply #11 on: 07 April 2009, 21:25:16 »
Sounds like a dowty seal - same as you'd use on a coolant bridge.
Anyway, they don't remove the sump plug to do oil changes these days - they stick a hose down the dip-stick pipe and suck the oil out!
unlucky alf
  • worksop, notts
« Reply #12 on: 07 April 2009, 22:02:27 »
cheers for the offer pete, the thing is ive fitted it back in now, but if anybody else knows the sump plug size then please let me know, meanwhile i`ll hunt for the info :y
Richie London
  • heathrow
« Reply #13 on: 07 April 2009, 22:27:25 »
is it the copper ring wat goes on the sump lug, if so i have one here.
« Reply #14 on: 07 April 2009, 22:33:34 »
2 different sizes fitted to tractor.  As said earlier, should get sump washer in oil filter pack (along with the rubber rings for filter itself)
« Last Edit: 07 April 2009, 22:33:43 by TheBoy »
Page created in 0.024 seconds with 16 queries.
