Author Topic: It failed....  (Read 1288 times)
Omega man 2
It failed....
« on: 11 April 2009, 17:18:01 »
Just got back from the test after hearing that my handbrake needs adjusting, my emissions are for times the limit and one of my rear shocks is leaking. :'( :'(
Mind, only the handbrake worries me as I'll just clean up the shock before heading over next time and I think some stupidity on my part was responsible for the emissions.
HolyCount
Re: It failed....
« Reply #1 on: 11 April 2009, 17:19:38 »
Well -- hopefully the retest should see it OK then  :y
Re: It failed....
« Reply #2 on: 11 April 2009, 17:21:23 »
Sorry to hear that! :'(
If you don't know already the following is an excellent guide by Mark to adjust the parking brake:
http://www.omegaowners.com/forum/YaBB.pl?num=1152564750
 :y :y
Omega man 2
Re: It failed....
« Reply #3 on: 11 April 2009, 17:22:59 »
 :y :y
I'll just get my spanners out
Re: It failed....
« Reply #4 on: 11 April 2009, 17:24:25 »
Unlucky, least they shouldnt be too hard to fix.
Thing with the handbrakes is to use em, and drive with on for a bit now and again, keep em biting.
Re: It failed....
« Reply #5 on: 11 April 2009, 17:24:43 »
 :y :y
Yep, it don't take long! :D :D ;)
unlucky alf
  • worksop, notts
Re: It failed....
« Reply #6 on: 11 April 2009, 17:27:30 »
good luck mate & go easy pulling the disc off as you dont want to rip the retention pins out of the back plate :y
Omega man 2
Re: It failed....
« Reply #7 on: 11 April 2009, 17:45:21 »
Right I've got the drivers side disc off (yes I am that quick :D :D )
It came off very easy so I assume that there's a bit of play between the shoes and disc, So could I adjust it here?
Now, when I pull the brake only one shoe moves but I only removed and cleaned the acuator about two weeks ago :-?
Re: It failed....
« Reply #8 on: 11 April 2009, 18:00:41 »
Its all in the guide.....have you slackened the hand brake cable off?
Omega man 2
Re: It failed....
« Reply #9 on: 11 April 2009, 18:03:27 »
Yes :y :y
The tester said that the passenger side was fine and there was an imbalance of 75%.
Re: It failed....
« Reply #10 on: 11 April 2009, 18:06:11 »
In which case you probably have to remvoe the lower pivot and take it apart, clean well an re-grease on assembly
