Author Topic: Camcover gasket source - question  (Read 3724 times)
Re: Camcover gasket source - question
« Reply #15 on: 28 April 2009, 21:08:03 »
They werent vectra gaskets :)
Well if they were joined in the middle, they sure weren't Omega gaskets!
« Reply #16 on: 28 April 2009, 21:10:51 »
It is interesting that you should say that. I had a similar conversation with autovaux recently. when I asked for genuine gaskets he said he had some that were made in the same factory as GM ect.. ect.. I then said I had heard that after market gaskets are prone to leakage, and he replied " we used to have a problem with complaints about inferior gaskets but since we have sourced these from Elring who make gaskets for GM we havent had any problems" A set of cam cover gaskets duly arrived in a bag marked 'Elring' but I was a bit disconcerted when I realised that there were 2 pairs of gaskets moulded together and I would have to seperate them with a stanley knife. They looked more like they had come out of a lucky bag than a factory that makes genecticaly modified gaskets.
That's vectra gaskets mate   ::)
Nope, thats Elring non gen gaskets!
The vectra ones have a much wider base.
« Reply #17 on: 28 April 2009, 21:16:06 »
So they don't even fit - you need to cut them?
That's terrible!!!!
Bent valve
« Reply #18 on: 28 April 2009, 21:16:15 »
yes they have a much wider base and they dont have a solid half moon bit, and I know because I have fitted vectra cam covers to my 2.5
« Reply #19 on: 28 April 2009, 21:30:49 »
That's terrible!!!!
They are elring for Omega, but need modifying to fit.
tmx
  • Herefordshire
    • 3.2 MV6 2002
« Reply #20 on: 28 April 2009, 21:56:39 »
big mistake you will eventually blow your rear crank seal thus expelling oil over the clutch and causing you £££ thats what happens to all v6 vectras eventually
so vectra gaskets wont fit a 3.0 then ah well ill ebay my'n
Bent valve
« Reply #21 on: 28 April 2009, 22:13:41 »
 No fear of oil being deposited on my clutch, its an auto ;D
As long as breathers are kept clear, theres no problem with vectra covers ,unlike crap plastic omega covers they do provide an efficient oil seal. Ive had mine on for 18,000 miles now with no problems.
 Although I have heard of this argument about blowing seals ect. and
 I have been pondering how to incorperate some sort of pressure relief valve into the oil filler cap which ejects excess crankcase pressure into the plenum instead of blowing gaskets.
 If you have any vectra covers give me first refusal :y
« Last Edit: 28 April 2009, 22:18:04 by Bent_Valve »
« Reply #22 on: 28 April 2009, 22:17:21 »
Disagree - the Omega ones are perfectly good enough if not fitted by a mechanic who doesn't know what he's doing.
There is no such thing as 'warped cam covers', that particular myth is one that is spread by mechanics to cover their lack of compitence.
ians
  • Reading
« Reply #23 on: 28 April 2009, 22:23:18 »
My Autovaux Elring ones came with instructions for separation. I assume the bridging bit is just part of the manufacturing process.
and yes they did leak after 6 months or so, and Autovaux did give me my money back to be fair.  But not correct of them to say they have had no problems with Elring.
Anyone who bought them and found they leaked should complain - that way they will get the message.
Autovaux also replaced my slightly too tight aux belt without question,  so I do rate them for customer service.
Bent valve
« Reply #24 on: 28 April 2009, 22:27:57 »
   I am not saying that omega covers are crap because they warp, they dont. they simply have far less surface area of gasket coverage  than vectra covers. as the engine wears and produces more crankcase pressure and the breathers become restricted the gaskets blow.
 Far better in my opinion to fit vectra covers if available and keep the breathers clear.
HerefordElite
  • Hereford
  • Welcome to the Shire
« Reply #25 on: 28 April 2009, 22:29:35 »
i did rate them but they've let me down by still not returning my £115 deposit for a camlocking kit after 2 weeks :-/
miggy
« Reply #26 on: 28 April 2009, 22:31:28 »
No. Buy a Merc if you want reliable. if you want something to do and you dont play golf then buy an Omega, it will give you many happy hours of fault finding & rectifying ect..
Do you like miggys...... ;D ;D ;D ;D
Bent valve
« Reply #27 on: 28 April 2009, 22:32:16 »
 Mine didnt come with instuctions for seperation, however I will be delighted if they start to leak soon because that will mean I've got my engine running again ;D
miggy
« Reply #28 on: 28 April 2009, 22:33:06 »
 :y :y Fingers crossed.
Bent valve
« Reply #29 on: 28 April 2009, 22:38:04 »
  Its very difficult to type with crossed fingers :) But they are!!
