Author Topic: She failed............who wants the work?  (Read 6695 times)
Dusty
  • Shropshire
  • Erotic Romance Author
« on: 06 May 2009, 15:47:54 »
My miggy failed today :'( :'( :'(
On 3 items :
1. Both front discs excessively pitted (3.5.1h)
2. N/s Rear brake pipe excessively corroded (3.6.B.2c)
3. O/S rear coils spring incomplete (2.4.C.1a)
There was also 2 advisories
1. Rear brake pads wearing thin. (3.5.1f)
2. Rear exhaust has part of the system deteriorated (7.1.1a)
Could have done without this but that's life. :-/
I've been told that a partial re-test fee will be payable if someone other than the garage repairs it.
The items they tell me I require are two front discs plus pads. Rear brake pipe, and O/S rear coil spring.
If anybody fancies a trip to South Lincolnshire to meet myself and Mr Dusty and can do it for a reasonable price, then let me know.  :-* :-* :-* :-* :-* :y
The work has to be done within 10 working days
« Last Edit: 06 May 2009, 15:49:32 by Dusty7 »
Omegadoha, Desert Member
  • Doha, Qatar
Re: She failed............who wants the work?
« Reply #1 on: 06 May 2009, 15:51:21 »
Can't help but my condolonces on the failure. :(
crazyjoetavola
« Reply #2 on: 06 May 2009, 15:56:02 »
Sorry to hear that Dusty :(but a trip to the beloved mainland to help you out would be rather excessive in this instance ;)Hope you get sorted out without too much trouble :y :y
tmx
  • Herefordshire
    • 3.2 MV6 2002
« Reply #3 on: 06 May 2009, 15:56:29 »
I had that on the RH Exhaust Centre Silencer to backbox pipe i looked at it and it was abit rusty i thought the tester was being a tit!
least it didnt fail on serious issues ie Emissions/corroded mounting points
« Reply #4 on: 06 May 2009, 15:57:50 »
brakes are easy, around £80 for discs and pads on TC.
Coil springs get RYB, around £40 the pair
Not sure on brake pipe, depends where it is, might have to run a replacement
« Reply #5 on: 06 May 2009, 17:08:48 »
Unlucky  :'(
unlucky alf
  • worksop, notts
« Reply #6 on: 06 May 2009, 17:17:05 »
bit of a shite garage if they are going to charge you for a partial test just because their not doing the work >:(,its not like there is a lot there to retest, i know they are entitled to but i have yet to find a garage that implements it, good luck with it anyway :y
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
« Reply #7 on: 06 May 2009, 17:25:58 »
I thought you have a few days to get it fixed before they re charged you  :-?
nick v6
  • walsall / west midlands
« Reply #8 on: 06 May 2009, 17:27:43 »
some places rob you by saying
if you take the car away for the work to be done there is a re-test fee
but if you leave the car with them for them to do the work its a free re-test
the place i use for mot's don't charge a re-test fee
but i know of 1 garage that charges the full test fee again
« Reply #9 on: 06 May 2009, 17:33:16 »
By rights they should charge for a full retest if the work involves touching anything else testable. In this instance the wheels have to be removed so a full test is (supposedly) required.
Admittedly most places don't do this but it's there in writing ::) ::)
nick v6
markey mark
  • SLady bitshorpe north lincs
« Reply #11 on: 06 May 2009, 17:52:12 »
mot test can not remove any parts !!!!! most place charge retest nowadays with it all being on computer they have to allocate time now and we all know time is chargable  :y
markey mark
« Reply #12 on: 06 May 2009, 17:52:51 »
i would do it dusty but you would have to come to me :(
« Reply #13 on: 06 May 2009, 17:55:46 »
I thought you were in Shropshire not Lincolshire!
« Reply #14 on: 06 May 2009, 17:58:15 »
I know... Point being???
If the wheels are removed they could be re-fitted incorrectly which is a fail. Hence, anything which involves removal of wheels should have a full re-test
And you're right... Most places are now charging as a re-test takes up computer time which could have been used for a full test. Luckily the place I use doesn't :y :y :y :y
