Pages: 1 [2] 3  All   Go Down
Author Topic: TD Locking Kit  (Read 2911 times)
Re: TD Locking Kit
« Reply #15 on: 12 January 2009, 12:55:01 »
As MDTM says, you cannot skim this head.  If you have head damage (either caused by hgf or cracking of the head) a replacement head must be sought...
Re: TD Locking Kit
« Reply #16 on: 12 January 2009, 13:49:16 »
He is taking the head to a place who pressure tests em, so will find out if its ok or not that way.
Re: TD Locking Kit
« Reply #17 on: 13 January 2009, 08:35:29 »
Has anyone taken the camshaft of one of these?
Did you use the 'special tool' as described in the manual or just undone the bearing caps progressively and carefully?
Re: TD Locking Kit
« Reply #18 on: 13 January 2009, 19:00:56 »
only of the head I didn't want.  Just undid them, no issues, but then its never going back together as its slowly going to landfill
Re: TD Locking Kit
« Reply #19 on: 15 January 2009, 19:18:37 »
Right, he has just got it back from the engineers....
It held pressure, but was slightly warped, so they skimmed it without his consent!
They said it was ok on this one as there are 2 types of 2.5 TD...
This one has recessed swirl pots, and was therefore ok to skim.  :-/
Reassembly time now, and he is really hoping for the best.
Re: TD Locking Kit
« Reply #20 on: 15 January 2009, 19:19:55 »
both vx docs and bm docs say no to skim...  ...but if it cures his prob :y
Re: TD Locking Kit
« Reply #21 on: 15 January 2009, 19:20:36 »
might need to adjust hg to bring compression ratio back to what it should be
Re: TD Locking Kit
« Reply #22 on: 15 January 2009, 19:22:17 »
Yes, you and Mark both said, the manual says.....but it does seem skimmable form what he said.
Were your swirl pots recessed or sticky out?
Re: TD Locking Kit
« Reply #23 on: 15 January 2009, 19:23:20 »
both heads (u25dt and x25dt)  recessed
Re: TD Locking Kit
« Reply #24 on: 15 January 2009, 19:28:44 »
Thy sit almost flush....trouble is skimming reduces the amount of metal holding thm in and these are prone to cracking at the best of times!
The other issue is the increase in compression ratio!
Re: TD Locking Kit
« Reply #25 on: 15 January 2009, 19:30:33 »
Have seen something about 2 different thinknesses of HG
Guess its hope for the best time, and hope they havent taken much off!
Back to the original issue of blowing a hole in the rad tank, so you think this could cause it?  I would have thought a hose, or most likely the header cap would go 1st?
Re: TD Locking Kit
« Reply #26 on: 15 January 2009, 19:37:34 »
Depends if the rad was on its way out.
Orig rad on mine looks like its had a repair (they are expensive). Still in garage if he wants it, but not really postable.
Re: TD Locking Kit
« Reply #27 on: 15 January 2009, 19:38:20 »
It was the 3rd rad to go this way!  in 6 months!
Sure you dont wanna come to the Chester Meet ;)
Lol, its in a Range Rover, so doubt it would fit?
« Last Edit: 15 January 2009, 19:39:16 by jimbob »
Re: TD Locking Kit
« Reply #28 on: 15 January 2009, 19:40:16 »
Mine normally did the cap. Got through loads of them.  Also did a bodged bolt closing off extra outlet when I used a v6 bottle once :o
Re: TD Locking Kit
« Reply #29 on: 15 January 2009, 19:42:15 »
Got me thinking, is the rad easily accessible?  If so any chance of the measurements, if they are the same.....they are on TC ;)
Pages: 1 [2] 3  All   Go Up
