Pages: [1] 2 3  All   Go Down
Author Topic: TD Locking Kit  (Read 2910 times)
TD Locking Kit
« on: 08 January 2009, 14:40:06 »
Has anyone got a TD locking kit I could borrow for a short time?
Friend has a 2.5 TD Landrover, same lump as Omega apparently, and thinks his HG has gone....
Strange failure, he has blown the top out of 3 radiators now, over 6 months.  He is reluctant to spend another £250 on another without looking for the real problem.
Not convinced on the HG idea, but he want to do the head to make sure.
I remember something being made from TB's door when he did the job, but has anyone got a kit available we could borrow?
Cheers
Re: TD Locking Kit
« Reply #1 on: 08 January 2009, 15:44:36 »
TB had one....
Re: TD Locking Kit
« Reply #2 on: 08 January 2009, 18:39:18 »
I have the locking kit, and the pdf. I am missing the tool to compress tensioner, and my gargae door will not be dismantled for it.
Re: TD Locking Kit
« Reply #3 on: 08 January 2009, 18:40:48 »
Any chance of bunging it in the post tomorrow?
If there is I'll check if its of use without the compressor.
Cheers
Omegatoy
  • UK
Re: TD Locking Kit
« Reply #4 on: 08 January 2009, 19:21:30 »
its not your garage door its your leccy opener!!!! think you should lend it to him to do the job!!! ;D
tool is easy to make buddy, its just what I made it out of the boy doesent like!!! :y
dieseldean
  • chesterfield
Re: TD Locking Kit
« Reply #5 on: 08 January 2009, 19:49:50 »
could use one myself when i get round to sorting out my tractor
Re: TD Locking Kit
« Reply #6 on: 08 January 2009, 20:00:27 »
Cheers
I'll PM you pdf, I'll try to get locking kit in post if I can find it tomorrow.
Re: TD Locking Kit
« Reply #7 on: 08 January 2009, 20:33:02 »
Cheers matey :)
Re: TD Locking Kit
« Reply #8 on: 08 January 2009, 21:07:03 »
pm me your addy jimbob
Re: TD Locking Kit
« Reply #9 on: 12 January 2009, 10:43:03 »
Huge thanks for supplying the Kit Uber fast, and for the technical advice  :y
The Head is off,
The gasket 'looks' ok, but does have some dulled areas?
Getting it skimmed before reassemby.
fingers crossed!  Trouble is it can go so long before issues, it will be a long time before success can be assumed  :-/
« Last Edit: 12 January 2009, 10:43:48 by jimbob »
Re: TD Locking Kit
« Reply #10 on: 12 January 2009, 10:47:54 »
The Head is off,
You cant skim a diesel head!
Re: TD Locking Kit
« Reply #11 on: 12 January 2009, 10:52:04 »
You need also to check the swirl pots for crackng
Re: TD Locking Kit
« Reply #12 on: 12 January 2009, 10:56:14 »
Why arent they skimmable?
Pots will be thoroughly checked.
Re: TD Locking Kit
« Reply #13 on: 12 January 2009, 10:58:51 »
Because the swirl pots etc are inserted into the head and as a result it thins the metal on them...it can also cause significant increases in compression.
Many modern heads cant be skimmed.
And anyway, you should not skim a head unless it need it so check its flat first!.
Re: TD Locking Kit
« Reply #14 on: 12 January 2009, 11:01:14 »
Cheers, rethink in progress!
Pages: [1] 2 3  All   Go Up
