Author Topic: When you change an abs ecu...  (Read 1973 times)
« on: 01 March 2007, 18:40:18 »
do you have to bleed the brakes  :-? :-?
Re: When you change an abs ecu...
« Reply #1 on: 01 March 2007, 18:58:28 »
I think you do. I also think you will need Tech 2 as well.
Omegatoy
  • UK
« Reply #2 on: 01 March 2007, 19:08:58 »
Why the hell would you want to bleed the brakes after an ecu change? your not affecting the fluid level or anything else? the ony time you should have to bleed the brakes is during a fluid change or a brake pipe change,
Omegatoy
« Reply #3 on: 01 March 2007, 19:14:10 »
For the hell of it. My mistake I didnt see the ECU bit :-X
« Reply #4 on: 01 March 2007, 19:53:43 »
Omegatoy
Why because thats what the vaux man told me but vaux=trouble=more money for them= money of of my pocket etc etc so i dint think i will
« Reply #5 on: 01 March 2007, 20:50:08 »
If it is not from the same engine and transmission type, or you dont know, then
Get in on tech2 and set to your car.
MartinP
  • Dudley
    • BMW 320D
« Reply #6 on: 02 March 2007, 19:57:35 »
Omegatoy
I can confirm that you do not need to bleed the brakes. The only reason the Vaux guy would need to is because they would take half the engine out and put the servo unit on the bench to change the ECU  :D
unlike us enthusiasts  8-)
« Last Edit: 02 March 2007, 19:58:07 by issunaz »
