Author Topic: That was close (I hope!)  (Read 1796 times)
« on: 03 September 2009, 16:34:32 »
Just done 100 odd miles on the motorway (longest trip since doing hbv)
1/2 a mile from home, Im thinking the car has done well, no gearbox warning, and no coolant topup needed  :D
then, up pops Automatic Gearbox, Up pops Coolant warning....temp guage shoots to max, warning light comes on  :'(
chuck it in a layby I happen to be passing....
pop the bonnet, and the bottom bulkhead hose has popped off, and im thowing coolant everywhere  :'(
i had 2 gallons in the car....so topped it up after reconnecting hose and got home.
Heres hoping there is no more damage  :-?
Debs.
Re: That was close (I hope!)
« Reply #1 on: 03 September 2009, 16:38:20 »
 :oOh gawd....what a heart stopper!:'(
kris
  • manchester
« Reply #2 on: 03 September 2009, 16:41:33 »
very close james. hope no other damage was done
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
« Reply #3 on: 03 September 2009, 16:45:01 »
Close, fingers crossed everythings OK.
I like red cars
« Reply #4 on: 03 September 2009, 19:03:43 »
I think you catch in the correct time..or you wont be able to continue..and at least if there was damage even some, the car wont pull like before..
« Last Edit: 03 September 2009, 19:04:27 by cem_devecioglu »
« Reply #5 on: 03 September 2009, 19:06:10 »
Fingers and legs crossed Jb - here's hoping you're in the clear :y :y :y
STMO999
« Reply #6 on: 03 September 2009, 19:08:11 »
Good God! If you've broken it Jimbob, it could cost as much as £27.50 to replace. ;D
« Reply #7 on: 03 September 2009, 19:11:48 »
had a play now the car is cold....and that pipe wont 'latch' back on  :'(
it will have to wait till after newent  >:(
« Last Edit: 03 September 2009, 19:12:07 by jimbob »
mantahatch
« Reply #8 on: 03 September 2009, 19:25:22 »
Hi Jimbob, hope everything is ok with the car, I had similar with the pipe not latching properly on my previous Omega, and as I recall I had to really really push it on hard before it would latch.
HTH
Mike
« Reply #9 on: 03 September 2009, 19:29:20 »
I hope that will do the trick, in my haste im now covered in blood, so it can wait till after the weekend, it felt as far as it would go though  :-/
« Reply #10 on: 03 September 2009, 20:31:38 »
Your more than welcome to drop it off here on your way through and I will have a play, then pick it up on the way back ;)
« Reply #11 on: 03 September 2009, 20:33:03 »
Ah, its the car your using to go to Newent. I should have read the whole thread ::)
« Reply #12 on: 03 September 2009, 20:48:24 »
cheers, mine is staying on the drive cheers, going in hers  :y
more reliable at the mo, and it has aircon  ;D
« Reply #13 on: 03 September 2009, 22:03:35 »
Clean the bulk head pipe off and put a wipe of KY on on it (do you have any?).
Push the hose fitting back on whilst giving a good screw motion.
Then push the latch in.
« Reply #14 on: 03 September 2009, 22:05:54 »
cheers Mark, will have a try at that, sure we have some lube somewhere  ::)
