Author Topic: extension lead for cigrette socket  (Read 3024 times)
r1
  • nottingham
« on: 12 October 2009, 21:42:12 »
my mate wants one of these for when he goes camping about 20foot but cant find one any where ,can anyone help
Re: extension lead for cigrette socket
« Reply #1 on: 12 October 2009, 21:44:41 »
maplin do em
waspy
« Reply #2 on: 12 October 2009, 21:44:52 »
Make one :y All the parts can be purchased & they're not expensive
KillerWatt
« Reply #3 on: 12 October 2009, 21:54:28 »
Don't forget to take in to account Vr, Vc, or Vl (depending on what you intend to plug in).
« Last Edit: 12 October 2009, 21:54:41 by KillerWatt »
r1
  • nottingham
« Reply #4 on: 12 October 2009, 22:17:48 »
maplin do em
thanks had a look but c ant find anything will give them a call
« Reply #5 on: 12 October 2009, 22:24:12 »
maplin do em
http://www.maplin.co.uk/Module.aspx?ModuleNo=1056
« Reply #6 on: 12 October 2009, 22:24:19 »
One of these:y  :y It's only 10 ft though  :(
« Reply #7 on: 12 October 2009, 22:27:06 »
Or ....... these too!  :y :y
KillerWatt
« Reply #8 on: 12 October 2009, 22:29:23 »
Keep the suggestions coming, I'm just as comfortable with car electrics as what I am domestic & commercial  ;D
r1
  • nottingham
« Reply #9 on: 12 October 2009, 22:46:00 »
hi thanks the maplins reel is the same as the towsure and ebay and a lot cheaper not sure if its long enough still he could always buy 2
unless anyone has anything better???
thanks
KillerWatt
« Reply #10 on: 12 October 2009, 22:49:24 »
thanks
Might be an idea if you tell us what your mate thinks he's plugging in, because those el cheapo extension leads tend to act as the fuse BEFORE the actual fuse in the car gets a look in.
« Reply #11 on: 12 October 2009, 22:57:01 »
thanks
 ;D
There's also the fact that the lighter socket isn't permanently live. You'd need to leave the keys in the ignition.
I just use a jump-start battery pack in the tent. Not worth messing about connecting up to the car IMHO.
KillerWatt
« Reply #12 on: 12 October 2009, 23:02:27 »
Spot on Kev  :y
They are useless for starting anything that has a real engine, but (as you say) great for powering up miscellaneous crap in the tent.
LFF64
  • HADDENHAM BUCKS
    • 64 insignia CT Nav 4x4
« Reply #13 on: 12 October 2009, 23:04:16 »
I just read this and as Kevin said the cig socket wont be live anyway with keys out of the ignition on the Omega assuming it is an Omega of course  :y
« Reply #14 on: 12 October 2009, 23:04:26 »
...... because those el cheapo extension leads tend to act as the fuse BEFORE the actual fuse in the car gets a look in.
I was using one of these
for my telly (about 4A IIRC) in the caravan. The telly stopped when it all melted because nothing had been tightened up, and one of the terminals had more insulation under the screw than wire!  >:(  >:(
