Author Topic: central heating problem  (Read 1621 times)
Richie London
  • heathrow
« on: 17 October 2009, 12:28:37 »
all my rads are getting hot except my bathroom one.not that im a southern softie that needs his heat   ::) any ideas why. have bled the rad but its ok. was working last time i used it but that was about 8 months ago
Re: central heating problem
« Reply #1 on: 17 October 2009, 12:40:51 »
Shut the rads off except the bathroom, boiler on full, when bath rad gets hot open other rads accordingly. Furthest from boiler open fully then work back to the nearest to the boiler opening valves incrementally
Richie London
  • heathrow
« Reply #2 on: 17 October 2009, 12:42:50 »
are we talking about the central heating boiler or the wife as im divorced   ;D ;D ;D
cheers rob  :y
« Reply #3 on: 17 October 2009, 13:39:51 »
No nancy boy central heating when I was a nipper.......ice all over the inside of the windows was common........and that was in the days when we had PROPER WINTERS.. ;D ;D ;D
I was informed by my parents ......that this deprivation  of heat was "character building"....read f###ing freezing  :o :o ::) :y
Richie London
  • heathrow
« Reply #4 on: 17 October 2009, 14:13:33 »
i used to sit in my bedroom with my coat and a hat on it was that cold, used to get in bed then get undressed. walk 8 miles to work in the winter when there was so much snow the buses never came out the garage. but thats what you did then, just got on with your life with all these things going on. now its too cold in the class, send them home
Richie London
  • heathrow
« Reply #5 on: 17 October 2009, 14:14:59 »
getting back to my heating. tried what you said rob but still no good. i should point out that if my hot waters on my bathroom rad should come on. but noooooooooo   ;D ;D
Selseybill
  • La Rochelle
    • 2.0 pre face, 2.2 CDX est
« Reply #6 on: 17 October 2009, 14:25:09 »
Have you a combi or a condensing boiler ?
« Reply #7 on: 17 October 2009, 14:41:16 »
Does it have a thermostatic valve on it?
Plomien
  • Swansea
    • Landrover Freelander TD4
« Reply #8 on: 17 October 2009, 15:26:03 »
Sounds like the valves on the rad are stuck closed
Ghost
  • Seaham, North East england
    • 2.6 V6 CDX Estate
« Reply #9 on: 17 October 2009, 17:13:51 »
Are both sides Fully open?
Had the same prob here was one valve not fully open.
He who brakes Looses
To old to die young
dad1uk
  • Birmingham
    • Vauxhall Zafira 2.2
« Reply #10 on: 17 October 2009, 17:42:10 »
Try turning all the other rads off except for the bathroom one. I had this once, and this cured it. Once the rad has warmed up put the others back on.
best wishes
Simon.
Chris_H
  • E London/Essex UK
    • Jag XF Portfolio S 3.0D
« Reply #11 on: 17 October 2009, 17:58:26 »
If it has a thermostatic radiator valve (TRV) on it, these often seize up in the summer from being closed too long.
If you can remove the head, you may find a small pin that operates the valve.  Pressing that repeatedly with a coin to spread the load or tapping very lightly with a hammer can restore the movement into it.  It should move about 2-3mm.
First Vauxhall - PABX Cresta; Previous, previous Vauxhall - 3.0 12v Senator CD; Previous Vauxhall Omega Elite 3.0V6 Saloon Auto
Lioned
  • South East London
« Reply #12 on: 17 October 2009, 18:51:15 »
If you have a conventional system with an indirect hot water cylinder,there may be a 'bleed' vent on top of the 'loop' that goes through your cylinder,as your bathroom rad is conected into that try venting that (but be careful taking the screw off as the rubber gasket often sticks and if it comes flying off you'll loose it).
Richie London
  • heathrow
« Reply #13 on: 17 October 2009, 20:05:05 »
tried it. didnt work
STMO999
« Reply #14 on: 17 October 2009, 20:12:49 »
'it it wiv a nammer :y
