Pages: 1 [2] 3  All   Go Down
Author Topic: Here is an interesting concept....  (Read 3757 times)
Re: Here is an interesting concept....
« Reply #15 on: 19 October 2009, 16:03:14 »
Standard engine, with 1 cylinder having 4 valves and a bigger combustion area to suit.
Extra cam only works the extra 2 valves.
Bigger centre cylinder balances out the 2 smaller ones as well.
« Reply #16 on: 19 October 2009, 16:12:51 »
But look at how the cams are driven. The exhaust valve on the centre cylinder opens once per revolution.  :-?
« Reply #17 on: 19 October 2009, 16:22:01 »
And the valves on number 1 &3 cylinders are both driven from the same cam,not 1 inlet and 1 exhuast valve  each. :-/
« Reply #18 on: 19 October 2009, 16:39:16 »
Yep, and that cam rotates at half crankshaft speed. Therefore, 1 and 3 are definitely 4 stroke cylinders. Looking at the lobes that drive their valves the valve timing looks pretty conventional too.
.. And the other pair of valves on cylinder 2 are driven by the "4 stroke" cam. The timing of those valves is the same as the adjacent exhaust valves on cylinders 1 & 3.  :-/
Can you see why I wanted to see the manifolds yet?
« Reply #19 on: 19 October 2009, 16:41:24 »
Hmm. I'd be interested to see the manifolds.
Looks like an idea from the age of steam re-hashed if I'm on the right lines...
Either that or the chap who did the valvegear had had one too many.
That is exactly what I think Kevin.  Compounding.  Two high pressure cyclinders and one low. :y :y :y :y
Brick Tamland
  • Dublin
  • Good one!
    • '98 2.5 Manual
« Reply #20 on: 19 October 2009, 16:44:47 »
Taking into account that the inlet cams are moving much faster, it looks like that all the valves on the center cylinder will all be open at the same time :-?
What ever it is it'll never be a replacement for a v8 so I dont like it  :D
Saving for one! All donations welcome, ask for details.
« Reply #21 on: 19 October 2009, 16:56:57 »
3 cylinder with 4 stroke me thinks..really interesting set up
« Reply #22 on: 19 October 2009, 17:09:26 »
Now you are starting to question yourselves. ::)
Both valves inlet and exhaust can be driven off the same camshft.
What is the rotational direction of the crank.
Which valves are the inlet valves?
Is this just an optical illussion psstake.
Is it indeed a petrol engine.
The mind boggles.   :o :o :o ::) :-X :-/
Andy H
  • Auckland
    • Mazda MPV
« Reply #23 on: 19 October 2009, 17:27:17 »
My theory....
Big centre piston acts as an air pump, camshaft running at crank speed controls intake valves to big piston.
Outer two pistons take turns to be charged with air from the big centre piston.
.. And the other pair of valves on cylinder 2 are driven by the "4 stroke" cam. The timing of those valves is the same as the adjacent exhaust valves on cylinders 1 & 3.  Undecided
The reason why the these valves open together is so the air from the big piston can pass into the little one.
Brick Tamland
  • Dublin
  • Good one!
    • '98 2.5 Manual
« Reply #24 on: 19 October 2009, 17:45:34 »
Is it one of these compressed air engines?  :-?
« Reply #25 on: 19 October 2009, 17:51:07 »
OK. My whole theory.
Two little pistons 1&3 work exactly like a conventional 4 stroke engine. Intake valves closest to the ends of the engine. Exhaust valves at the centre. Crank rotates clockwise viewed from the front pulley (cam belt tensioner arrangement proves that).
Exhaust valves from 1 and 3 feed into the large central cylinder so the exhaust manifold just connects the two pairs of valves at the centre rear of the head as we look at it.
Gases (still expanding) from the little cylinders exert pressure on the large piston thus recovering a bit more energy from the charge, increasing efficiency. Large piston exhausts through the pair of valves nearest to us, and driver from the front cam at crank speed (engine will exhaust once per crank rotation so the middle cylinder is effectively a 2 stroke).
No reason why it wouldn't scale up to a V8. Would be 12 cylinders by then though. 8-)
« Reply #26 on: 20 October 2009, 11:56:04 »
Correct, it is indeed a 5 stroke engine and is being developed by the legendary high performance engine maker, Ilmor
so, if we consider
http://www.omegaowners.com/forum/YaBB.pl?num=1222761905
We get all the benefits of opening the exhaust valve earlier and still get great economy as we can recover additional power using the thrid stroke!
And how may you ask can you get a 5 stroke engine, simples, there are only 5 truely active strokes
« Reply #27 on: 20 October 2009, 11:58:59 »
« Reply #28 on: 20 October 2009, 12:00:20 »
so, if we consider
I'm the same as my wife will tell you ::)
Chris_H
  • E London/Essex UK
    • Jag XF Portfolio S 3.0D
« Reply #29 on: 20 October 2009, 12:09:00 »
More info here:
http://www.ilmor.co.uk/concept_5-stroke_1.php
That's confused me.  I thought they had become Mercedes and were powering the Brawns, Maclarens etc.
First Vauxhall - PABX Cresta; Previous, previous Vauxhall - 3.0 12v Senator CD; Previous Vauxhall Omega Elite 3.0V6 Saloon Auto
Pages: 1 [2] 3  All   Go Up
