Pages: 1 2 3 [4] 5 6 7   Go Down
Author Topic: BT Broadband issue  (Read 6901 times)
Martin_1962
Re: BT Broadband issue
« Reply #45 on: 06 January 2010, 10:49:05 »
Just lost connection to office but the line is still up!
« Reply #46 on: 06 January 2010, 10:50:15 »
Your up SN is pretty low which will be limiting the up bandwidth....down looks fine though
Martin_1962
« Reply #47 on: 06 January 2010, 10:54:39 »
So how do I fix it?
Thanks
« Reply #48 on: 06 January 2010, 10:59:38 »
So how do I fix it?
Thanks
If you have eliminated all your stuff (wiring, filters, hub, extns, phones), then its for your ISP to get BT to fix it
« Reply #49 on: 06 January 2010, 11:00:40 »
What are the ADSL stats e.g. Noise margin and attenuation?
Off a BT Homehub??? ;D
You're having a Bobby Moore, ain't you!!!
I seem to recall being able to get the details by runnning Hub Manager
Select Advanced/Status/ADSL Line/Details.
Can also easily get it if you put alcatel's f/w back on
KillerWatt
« Reply #50 on: 06 January 2010, 11:00:56 »
I don't have to but the router has a username of        bthomehub@btbroadband.com but no password
Connectivity to Gateway (217.47.86.250)
Troubleshooting
Information for Helpdesk agents
Product Name      BT Home Hub
Firmware Version      6.2.6.E
Board Version      V10
ADSL Uptime      0 days, 0:47:27
Bandwidth      64 / 864
Broadband Username      bthomehub@btbroadband.com
Wireless Security      WEP-64
Wireless Channel      7
Firewall      Standard
VPI/VCI      0 / 38
Line Profile      Interleaved
Wi-Fi Community      No
I'd move up to WPA at the very least, and WPA2 if your hardware can manage it.
WEP can be broken in under a minute with ease, and the only knowledge required to do it is to look on YouTube.
Martin_1962
« Reply #51 on: 06 January 2010, 11:02:51 »
Troubleshooting
Board Version      V10
Bandwidth      64 / 864
Wireless Channel      7
Firewall      Standard
VPI/VCI      0 / 38
Wi-Fi Community      No
Too many non WPA devices >:( >:(
« Reply #52 on: 06 January 2010, 11:03:17 »
Troubleshooting
Board Version      V10
Bandwidth      64 / 864
Wireless Channel      7
Firewall      Standard
VPI/VCI      0 / 38
Wi-Fi Community      No
He has already said his crap hardware only supports WEP. Don't know enough about the DS to comment - Mrs TB's DS never connects to wifi.
Personally, I would kick the DS's off the network and WPA/WPA2 it. If necessary, just shove in an AP not connected to router just for DS to DS (assuming the DS can't do ad-hoc)
Martin_1962
« Reply #53 on: 06 January 2010, 11:03:52 »
So how do I fix it?
Thanks
PC->ethernet->HH->ADSL Filter->Socket
My ISP is BT
« Reply #54 on: 06 January 2010, 11:04:12 »
Yep, if it still as bad plugged directly into the master socket then and you have eliminated micro filters (although you can do a test on the master without one) and any possible new noise sources then its a call to the isp to investigate
« Reply #55 on: 06 January 2010, 11:05:04 »
Indeed, but you dont need to in order to get the info
Martin_1962
« Reply #56 on: 06 January 2010, 11:06:23 »
Well with wireless - 2 DSs they can ****** off, or I can break into someone elses wifi (joke)
PS3, and Wiiiii
I may cable the PS3 but I know it can do WPA, don't know about the Wiiiii
« Reply #57 on: 06 January 2010, 11:07:37 »
PS3, and Wiiiii
My wii uses WPA
Martin_1962
« Reply #58 on: 06 January 2010, 11:07:57 »
All kit is in my reach, PC. hub, filter, socket.
Martin_1962
« Reply #59 on: 06 January 2010, 11:10:13 »
Will move to WPA at the weekend then, but that is not my issue here
Pages: 1 2 3 [4] 5 6 7   Go Up
Page created in 0.209 seconds with 16 queries.
