Pages: [1] 2 3 4 5 6 7   Go Down
Author Topic: BT Broadband issue  (Read 6902 times)
Martin_1962
BT Broadband issue
« on: 05 January 2010, 17:15:47 »
64kbps downstream
1600kbps upstream
Normally 400 or so and 2880
India Telecom help are putting it onto an engineer they said (I think)
alunonhisown
Re: BT Broadband issue
« Reply #1 on: 05 January 2010, 17:46:39 »
BT Broadband as with other service providers slow the service down between 6pm and midnight, or there would not be enough bandwidth to go around.
Try a speedtest at
http://www.grc.com/x/ne.dll?rh1dkyd2
STMO999
« Reply #2 on: 05 January 2010, 18:17:28 »
373 and 4216.
sexydaz
« Reply #3 on: 05 January 2010, 18:46:05 »
Try a speedtest at
dont work
« Reply #4 on: 05 January 2010, 18:56:15 »
Try a speedtest at
Not entirely correct ;)
Some ISPs do nothing - Zen Internet being a prime example. You get whatever the product can deliver (if thats a contended service, obviously subject to contention).
Some ISPs do mild shaping - BT are an example, usually slowing down non web traffic, but otherwise, full capabilities of the product.
Some, Plusnet being the first to really use it hard, shape some of their products to make it almost unusable.
Wholesale charging structures, introduced to cut down the unsustainable p2p/nntp traffic at a wholesale level, have meant some of the oversubscribed ISPs have to shape heavier than others.
Most DSL and all cable services are contended, and if you have a load of heavy users shared with you, you may suffer whatever you have.
« Reply #5 on: 05 January 2010, 18:57:27 »
Know where your Home Gateway is?  If its Brum, I'm in that room on Friday, I could give it a good kicking if that helps (it won't, but would make me feel better!)
« Last Edit: 05 January 2010, 18:57:41 by TheBoy »
Pitchfork
  • Tadley (near Basingrad)
  • Barndances & Morris
« Reply #6 on: 05 January 2010, 19:04:58 »
Plusnet at 19:03
2790 Kbps download
681 upload
Is that good?
« Reply #7 on: 05 January 2010, 19:05:22 »
Plusnet at 19:03
2790 Kbps download
681 upload
Is that good?
meaningless
Pitchfork
« Reply #8 on: 05 January 2010, 19:06:27 »
please elucidate
« Reply #9 on: 05 January 2010, 19:09:44 »
please elucidate
Most ISPs shape their traffic to give artificially high speedtests, which don't match reality.
Plusnet are rumoured to be particularly bad for this.
Additionally, most of the speedtest sites will be affected by server load or, more likely, transit capacity/latency.
So all speedtests via the ISP are meaningless.
« Last Edit: 05 January 2010, 19:10:38 by TheBoy »
Pitchfork
« Reply #10 on: 05 January 2010, 19:10:58 »
please elucidate
This is what I used
www.mybroadbandspeed.co.uk
« Reply #11 on: 05 January 2010, 19:11:37 »
Try a speedtest at
If I use that site I get the following.(Something called Shields Up)
Port Authority Edition – Internet Vulnerability Profiling
by Steve Gibson,  Gibson Research Corporation.
Browser Reload Suppressed
For your security, your web browser's "reload"
function has been temporarily disabled
Allowing a web browser to "reload" a page which has already been sent to you creates a "security hole" that would allow someone using your computer at any later time to attain potentially private and personal information.
To safeguard your privacy we have disabled the browser's "reload" or "refresh" facility while you are in sensitive areas of our web site. Reloading pages will function normally once you have left this area . . . but until then please refrain from "reloading" pages.
You may press your browser's  [BACK]  button now to return to the page prior to the one you were just viewing.
Thanks very much for your interest and patronage.
[/b]
sexydaz
« Reply #12 on: 05 January 2010, 19:49:09 »
Try a speedtest at
[/b]
same here
jereboam
  • Suffolk
    • 1999 Omega Elite 3.0
« Reply #13 on: 05 January 2010, 19:50:16 »
Try a speedtest at
[/b]
I get the same thing - back and forward buttons in IE are disabled.
I haven't used ShieldsUp for a couple of years - used to be an excellent reference site for testing PC security before personal firewalls became common.  Gibson Research used to have a good reputation.
« Reply #14 on: 05 January 2010, 19:52:23 »
Try a speedtest at
[/b]
And equally a bad one, infamous for overblowing minor and non-issues, just to get his face in the press
Pages: [1] 2 3 4 5 6 7   Go Up
