Author Topic: Any plumbers?  (Read 1025 times)
Any plumbers?
« on: 07 January 2010, 19:41:34 »
The plumbing here is keeping me busy today!
Fixed the water supply, now a prob with sink.
Normal, typical, plastic? type sink.
When water in it, it weeps through where the drain attaches to sink.
Firstly, how does it come apart (presumably start by undoing screw in plughole), secondly, being kitchen sink, can't have it out of action for long, so would like all bits before I start, is it a rubber seal or similar? Or sealent?
I can nip to screwfix tomorrow (near the dealer I need to go to anyway), if I know what I need
Re: Any plumbers?
« Reply #1 on: 07 January 2010, 19:43:20 »
pick up my alloy locking key while your there, it should be around a tenner  :)
Nickbat
Re: Any plumbers?
« Reply #2 on: 07 January 2010, 19:44:51 »
Yes it's held on by the screw and it does have a rubber ring. Pretty standard item, IIRC.
sexydaz
Re: Any plumbers?
« Reply #3 on: 07 January 2010, 19:47:08 »
as far as i know there same as stainless with that black rubber seal last time i did mine  i put a smear of silicone on it
Re: Any plumbers?
« Reply #4 on: 07 January 2010, 19:52:26 »
STMO999
Re: Any plumbers?
« Reply #5 on: 07 January 2010, 19:54:47 »
is there a seal above sink as well as below?
Does this seem right?
http://www.screwfix.com/prods/50870/Plumbing/Plumbing-Accessories/Sink-1-Polywasher-89mm-x-49mm-Pack-of-10
Yup. rather expensive though. I got one at Graham Gratrix for 40p.
sexydaz
Re: Any plumbers?
« Reply #6 on: 07 January 2010, 19:56:52 »
below
STMO999
Re: Any plumbers?
« Reply #7 on: 07 January 2010, 19:57:57 »
below
Below yourself big boy :-*
STMO999
Re: Any plumbers?
« Reply #8 on: 07 January 2010, 20:03:06 »
The top one on this page is probably similar to your Jaime
http://www.plumbworld.co.uk/kitchen-sink-plumbing-wastes-314-0000
Re: Any plumbers?
« Reply #9 on: 07 January 2010, 20:05:03 »
2nd down is prob nearer
STMO999
Re: Any plumbers?
« Reply #10 on: 07 January 2010, 20:08:24 »
Here's an exploded view of it then:
http://www.plumbworld.co.uk/images/pwpe0/pwpe0001_8123_t.gif
« Last Edit: 07 January 2010, 20:08:39 by STMO999 »
Re: Any plumbers?
« Reply #11 on: 07 January 2010, 20:12:25 »
easy job.. 2 weeks ago repaired and changed most in the kitchen.. dont force too much or will drain again..
sexydaz
Re: Any plumbers?
« Reply #12 on: 07 January 2010, 20:25:28 »
below
if i was a big boy i could
and would ;D ;D ;D
