Author Topic: Any BT socket experts  (Read 2119 times)
Re: Any BT socket experts
« Reply #15 on: 01 March 2010, 14:09:08 »
So.....disconnect the extensions and then plug into the front face and repeat....ok?
Hes no got some secret phone somewhere plugged in without a filter has he?
Or an alarm system, sky box etc....
« Last Edit: 01 March 2010, 14:09:36 by Mark »
« Reply #16 on: 01 March 2010, 14:12:05 »
Yes, thats the next, no more phones, sky disconnected.
nothing else using the line,
all the extensions will be permanently disconnected this week, and 2 dect, 2 wired phones all being replaced with a quad pack.
if theres still a problem (guessing there wont be)  then a new splitting / filtering faceplate will go on.
« Reply #17 on: 01 March 2010, 14:16:22 »
hes not got some old extension bell wired in....there must be something else on the line somewhere.....again, one of the filtered faceplates would be the better solution.
« Reply #18 on: 01 March 2010, 14:19:25 »
the wiring is dodgy, and not really accessible, so removing it from the equation.  been fine for voice, but any adsl on the line and it is unusable.
« Reply #19 on: 01 March 2010, 14:30:16 »
Yeh, the extension wiring should make no difference, something is allowing the broadband to interfere with the voice.....and the only real thing that can do that is another un-filtered device on the setup....I wonder if the neighbour is making use of his line....(seen that once before)
Or a dodgy filter...
« Reply #20 on: 01 March 2010, 14:39:14 »
aye tis a weird one.
Spent hours playing with different permutations of phones / routers / filters.
Hence the remove the problem out the equation, be interesting to see if the new phones do it once extensions removed.
Has been tried with 2 faceplates now I think about it.....had a brass one originally, which he replaced with the plastic which he replaced a few years ago, due to noise on the line....he has had no end of grief with noise in the past, something not right somewhere, but all currently fine with the extra wiring out the equation.
« Reply #21 on: 01 March 2010, 14:40:09 »
A fault with the wiring can ime.  Particularly damp sockets, which tend to act a little like a diode between either A and B, or between B and ringer.  Damaged cable - white cable on outside wall, or plastered over cable - can also affect it, but that tends to give noisy voice as well, as invariably the actual conducters are damaged and corroded.
JB - when they pick up the phone, does the broadband cut off?  If so, that could well be a BT problem caused by an HR on the before the NTE5 (but normally close to NTE).
« Reply #22 on: 01 March 2010, 14:42:14 »
nope, using voice does not affect BB
(I used to have a great problem...If I used a modem on an adsl enabled and connected line - to dial into work, used to kill the broadband connection.  Hence buying those best quality filters, cured it instantly)
« Reply #23 on: 01 March 2010, 14:44:07 »
JB - I'm guessing your Father-in-law isn't near me, as if he is, I could pop around and take a looksie at it?
« Reply #24 on: 01 March 2010, 14:44:36 »
LOL, if I had a car ;D ;D   :-[
« Reply #25 on: 01 March 2010, 14:45:16 »
nope, just up the road from me
« Reply #26 on: 01 March 2010, 14:49:26 »
Ow well, there's your answer, hes in Wales, its water ingress, hes got a leek somewhere....
« Reply #27 on: 01 March 2010, 14:50:01 »
 ;D ;D ;D ;D
