Author Topic: Any BT socket experts  (Read 2106 times)
Martin_1962
« on: 28 February 2010, 12:10:30 »
I have had a ASDL V1.0 socket fitted with a  rounded top.
Through the post I have had an I-Plate insert
It doesn't look like I could fit both at the same time.
Which should be used please?
Thanks
Martin
I_want_an_Omega
Re: Any BT socket experts
« Reply #1 on: 28 February 2010, 16:21:56 »
Whats the I Plate insert for?
You shouldn't need anything other than the BT ADSL socket as you punch down the extension socket wiring inside it IIRC
Plomien
  • Swansea
    • Landrover Freelander TD4
« Reply #2 on: 28 February 2010, 16:43:12 »
if it is a built in filter then front plate should just unscrew off and replace it with the new plate
« Reply #3 on: 01 March 2010, 12:11:04 »
Forget the bloody iplate. It does little more than disconnect the ringing circuit (which is better done manually anyway).
It would appear than the SSF you already have is one of the best filters available, and is certainly what I use.
« Reply #4 on: 01 March 2010, 12:14:22 »
Ive just picked up an new set of dect phones for the father in law...
whenever his broadband router is turned on, there is a lot of 'modem' noise on the line IF and internal extensions are connected.
(tried all combinations of removing things and 3 different routers)
So unplugging the lot and having everything in the main socket.
Jobs a good un
« Reply #5 on: 01 March 2010, 12:16:16 »
Jobs a good un
Thats shite quality ADSL microfilters....
I still rate these:
http://www.adslnation.com/products/xte2005.php
« Reply #6 on: 01 March 2010, 12:19:44 »
Jobs a good un
I still rate these:
that was using those filters!  well the flying lead versions anyway.
and the same with no phones plugged in, just the extensions 'being there'!  right pain.
« Last Edit: 01 March 2010, 12:20:47 by jimbob »
« Reply #7 on: 01 March 2010, 12:22:04 »
Jobs a good un
I still rate these:
Well, they are pretty much the best you can get!
Do you still get the noise with no ADLS filter and just phone being used?
« Reply #8 on: 01 March 2010, 12:28:44 »
the noise is there the second the router is switched on.
tried a variety of free and my good filters (left over from when I installed a faceplate splitter / filter.
just phones connected, silence...
router plugged into any socket, noise
phones plugged in, or not, but extensions connected, noise.
router and phone plugged into test socket, silence.
played for hours, gave up, and he has 4 shiny new phones.
may put him on a split faceplate as well now, but doesnt really matter.
ring wire already disconnected anyway (as per iplate)
« Reply #9 on: 01 March 2010, 13:28:18 »
I'm with MDTM, does sound like filtering.
Unless the router was radiating something that the cordeless phones were picking up via aerial?
« Reply #10 on: 01 March 2010, 13:32:07 »
So are you saying that when the whole setup is plugged directly into the rear plate ...its all ok?
In which case....it sounds like the  front face of the NTE5(x) is at fault
« Reply #11 on: 01 March 2010, 14:00:08 »
tried 3 different routers, all the same, not all wireless enabled, and different filters, so happy all those ruled out.
Fault has to be either faceplate, or dodgy wiring (most likely from what I have heard  ::)
« Reply #12 on: 01 March 2010, 14:04:04 »
So, if you plug the microfilter directly into the master socket and have just the router and the phone connected, does it occur?
« Reply #13 on: 01 March 2010, 14:05:33 »
master socket yes, as extensions connected (with no phones in, same if phones connected)
test socket, perfect (extensions obviously now removed)
« Reply #14 on: 01 March 2010, 14:07:31 »
JB, how many extensions in the house, excluding master NTE5?
Can you tell if they are star wired, or spurred off each other?
