A rare opportunity....
Started by Marks DTM Calib, 04 April 2007, 11:37:57
hmmm without HID :(
no good replacements on an MV6 Estate then :(
Ive saved this seller as a favorite but the springs are no good for mine :'(
Admin
If you have an estate you want these! ;)
Work fine with or without HID's.
I have them on the MV6 (with HID's) and no problems (apart from potentially a speeding ticket!). :)
The Administrator.
HIDs make no difference (except they should be recalibrated after any suspension work).
Why are Xenon's mentioned then?
QuoteWhy are Xenon's mentioned then?
Probably because HIDs should be recalibrated after suspension work...
Where are the levelling sensors then?  thought (wrongly) they were on the spring
Both on the passenger side for the HIDs, the front is on the passenger front wishbone and the rear on the passenger trailing arm...
The self leveling sensor is on the drivers side trailing arm close to the diff...
cheers, head well and truely up me bum, still Im learning :)
