Author Topic: computer help  (Read 1606 times)
mantagte
  • great yarmouth
    • omega bmw maverick
computer help
« on: 05 April 2010, 15:47:04 »
swmbo's computer will not boot up
the cpu and psu fans run very slowly for about 5 seconds then stop, there are no beeps have disconected all drives and cards still the same
but if i take the 4 pin plug out off the motherboard which i think ssaid cpu on it both fans are back up to normal speed
any ideas
TIA
Re: computer help
« Reply #1 on: 05 April 2010, 15:59:57 »
did you tried another psu..
mantagte
  • great yarmouth
Re: computer help
« Reply #2 on: 05 April 2010, 16:02:42 »
yes tried another cpu still the same
Re: computer help
« Reply #3 on: 05 April 2010, 16:14:48 »
I mean power suppy unit..
mantagte
  • great yarmouth
Re: computer help
« Reply #4 on: 05 April 2010, 16:18:57 »
sorry Cem meant psu not cpu
gone brain dead  :-[
Re: computer help
« Reply #5 on: 05 April 2010, 16:36:32 »
gone brain dead  :-[
check the power on switch connection ..
try this route ;D :y
http://pcsupport.about.com/od/findbysymptom/ht/wontstart.htm
« Last Edit: 05 April 2010, 16:39:26 by cem_devecioglu »
mantagte
  • great yarmouth
Re: computer help
« Reply #6 on: 05 April 2010, 18:11:05 »
well i have got it down to either motherboard or cpu
as i took the motherboard out with cpu and put it in a known working case and it is still the same :(
Re: computer help
« Reply #7 on: 05 April 2010, 18:35:11 »
cpu's rarely fail..
Chris_H
  • E London/Essex UK
    • Jag XF Portfolio S 3.0D
Re: computer help
« Reply #8 on: 05 April 2010, 22:35:10 »
Look in the BIOS and see if there are any protections for cpu fan not spinning.
First Vauxhall - PABX Cresta; Previous, previous Vauxhall - 3.0 12v Senator CD; Previous Vauxhall Omega Elite 3.0V6 Saloon Auto
mantagte
  • great yarmouth
Re: computer help
« Reply #9 on: 05 April 2010, 22:48:47 »
cannot get into bios
does not run long enough
does not do anything really
no beeps or anything
only thing i did notice in the original case
when i push the power switch it lights up red
it used to light up blue
if its any help its a Packard Bell
Re: computer help
« Reply #10 on: 05 April 2010, 22:54:41 »
Have you cleaned all the dust out of the heatsink and fan, and put now heat sink paste on if you have had the CPU out.
Just sounds like the CPU is getting hot and shutting down/restting the computer.
Just a thought.
mantagte
  • great yarmouth
Re: computer help
« Reply #11 on: 05 April 2010, 23:06:27 »
yes have cleaned all the dust out
have not removed heatsink or cpu
as said if i remove the little four pin plug from near the cpu both fans run normally and the computer does not switch off but still does not beep to say there is a problem nor does it boot up
Re: computer help
« Reply #12 on: 05 April 2010, 23:10:31 »
remove the memory sticks, reconnect the 4 pin power .. try it .. should beep for no memory error...  if it doesn't my guess is the MB has had it  .... I have a couple of MB testers that plug in to PCI slots .. but they are not cheap ...
Re: computer help
« Reply #13 on: 05 April 2010, 23:12:07 »
Sounds like something (short circuit?) is dragging down the output of the power supply to me. Does any component on the motherboard get hot after a few attempts to switch on?
mantagte
  • great yarmouth
Re: computer help
« Reply #14 on: 05 April 2010, 23:34:03 »
removed memory stick still the same
no beeps no boot
