Author Topic: Shared Access Drive  (Read 961 times)
Tonka.
  • Lincoln, Lincolnshire
    • 2000 2.5 CDX
Shared Access Drive
« on: 02 June 2010, 20:47:38 »
We live next door to a rented property and we share the use of one driveway. The driveway leaves the road and passes between the houses then widens to give access to our respective garages.
Both myself and the tenant (next door) wish to improve the surface of the drive by laying gravel. The gravel will amount to about 12 tons. We are both willing to prepare the surface and level the gravel.
The problem is his landlord, he is as tight as they come. Our neighbour cannot even get him to fit curtain tracks or a shower curtain   ::)
We both want the improvement but I am loathed to spend money which will benefit him and the tenant will have full legal use of.
What is the best way to word a letter, which will convince him to part with the money. Bearing in mind we would share the cost and the labour would be covered by myself and neighbours.  ;)
Ideas please all   :y :y
The happiest people don't have the best of everything,
they just make the best of everything they have.
STMO999
Re: Shared Access Drive
« Reply #1 on: 02 June 2010, 20:58:59 »
I don't think you've got much chance of him parting with a penny. Why should he?
sexydaz
« Reply #2 on: 02 June 2010, 21:01:49 »
erm how bad is the current surface,i think i would get the tennant to look at his agreement and if it states (drive offroad parking)i would push the only reason i chose this property but its causing damage to my car and that the neighbour and myself are willing to do to the work if you chip in with the materials(failing that i will knock it off the rent) ::)
jereboam
  • Suffolk
    • 1999 Omega Elite 3.0
« Reply #3 on: 02 June 2010, 21:02:26 »
Is your car likely to be damaged if the surface isn't improved?  If so, you might point out to the landlord that he might be held liable.
Only a passing thought...
« Reply #4 on: 02 June 2010, 21:02:49 »
Where is the incentive for the landlord? :-/ :-/
If there is one then all you can do is emphasis that, and make sure he doesn't put your neighbours rent up!!! ::) ::) ::) :P
« Last Edit: 02 June 2010, 21:03:00 by Lizzie_Zoom »
Tonka.
    • 2000 2.5 CDX
« Reply #5 on: 02 June 2010, 21:07:57 »
All I can think is that the work would remove the ruts and make the place more presentable to his next tenant  :-/
But surely we have a duty of care to each other and that it must be kept accessible, and free from hazards.
I am thinking that we have joint responsibilities to maintain the access in good condition.
Does that sound reasonable?
HolyCount
« Reply #6 on: 02 June 2010, 21:08:31 »
Point out that his current tenant is willing to provide free labour --- so if he gets it done now it will be cheaper than if repairs are required in the future when he will be obliged to pay labour rates as well.
Might also be an idea to check the repair and maintenance covenants in the deeds ---- some specify repair schedules.
Peachy
« Reply #7 on: 02 June 2010, 21:16:35 »
I get the impression that the landlord is a little like
Nicholas van Hoogstraten here, which in my opinion you will get NAFF all done.
STMO999
« Reply #8 on: 02 June 2010, 21:19:12 »
Or.........the landlord might say.......eff off if you don't like it.
Peachy
« Reply #9 on: 02 June 2010, 21:21:46 »
EXACTLY what Nicholas van Hoogstraten would tell you. And if you don't pay the rent he has you killed, and then goes to court for manslaughter and gets 10 years and a bloody High Court Judge releases him for lack of evidence, the Jury thought there was evidence.
Bloody Mason's
STMO999
« Reply #10 on: 02 June 2010, 21:23:37 »
Bloody Mason's
His brother, Haagen Daas, makes ice cream I believe.
Tonka.
    • 2000 2.5 CDX
« Reply #11 on: 02 June 2010, 21:47:47 »
Thanks for the useful input. Letter on way  :y :y
