Author Topic: Hmmmmm  (Read 1421 times)
Hmmmmm
« on: 27 June 2010, 01:00:29 »
It seems that having a clumsy little woman pour a load of water over a mains socket does knock out the trips in the house, hence the outage a few mins ago....
Anyone know a good, cheap supplier of UPS batteries?
tidla
  • solihull
Re: Hmmmmm
« Reply #1 on: 27 June 2010, 01:04:06 »
drop a cable in from the lampost outside ::)
Plomien
  • Swansea
    • Landrover Freelander TD4
Re: Hmmmmm
« Reply #2 on: 27 June 2010, 08:34:07 »
Re: Hmmmmm
« Reply #3 on: 27 June 2010, 08:52:26 »
http://www.maplin.co.uk/Search.aspx?MenuNo=85959
Been there before, they are unsuitable sadly. Mdsbattery seem to be best bet currently, and that's where last lot came from
Re: Hmmmmm
« Reply #4 on: 27 June 2010, 08:57:10 »
Ive used MDS for a few things before  :y
Re: Hmmmmm
« Reply #5 on: 27 June 2010, 09:05:29 »
I take it the clumsy little woman is OK ;)
Mysteryman
Re: Hmmmmm
« Reply #6 on: 27 June 2010, 09:19:09 »
Kill two birds with one stone. Tell her she is fat and needs to lose weight and then wire her exercise bike to the server.
But before you tell her, where do we send the flowers? ;D
Re: Hmmmmm
« Reply #7 on: 27 June 2010, 10:27:13 »
Not too bad straight from Yuasa.
http://www.yuasabatteries.co.uk/np12-12-yuasa-11-p.asp
Re: Hmmmmm
« Reply #8 on: 27 June 2010, 10:28:56 »
... Might be worth checking that the UPS is floating them at a sensible voltage given the spectacular failure mode. Bear in mind that it's warm at the moment and the voltage should really be temperature compensated.
Re: Hmmmmm
« Reply #9 on: 27 June 2010, 10:57:17 »
I'm sorry to hear that, the consequences could have been dire - I do hope she wasn't injured.
Outages can aways be rectified. :y
Varche
  • Online Online
  • middle of Andalucia
    • Golf Estate
Re: Hmmmmm
« Reply #10 on: 27 June 2010, 11:53:09 »
MDS battery, that is where mine come from.
can't you fit poly bags over the sockets or have them moved higher up the wall? ;D ;D ;D ;D ;D
Re: Hmmmmm
« Reply #11 on: 01 July 2010, 21:35:50 »
H says, time for a curry?.... i know i know, i told her that wasn't the sort if help you where after but she wouldn't have it.  ;D
Chris_H
  • E London/Essex UK
    • Jag XF Portfolio S 3.0D
Re: Hmmmmm
« Reply #12 on: 01 July 2010, 23:11:56 »
I've used MDS 2 or 3 times for APC replacements and they are fine.  I drop in and they seem to know their stuff.  Also been around for quite a while now so hopefully won't disappear.
First Vauxhall - PABX Cresta; Previous, previous Vauxhall - 3.0 12v Senator CD; Previous Vauxhall Omega Elite 3.0V6 Saloon Auto
