Author Topic: Dishwasher, this time...  (Read 2561 times)
jereboam
  • Suffolk
    • 1999 Omega Elite 3.0
« on: 05 July 2010, 12:21:46 »
If this forum ever closes, I don't know where I'll go to get things fixed.
OK - dishwasher packed up a few weeks ago - we don't use it much, with just the two of us here.  I diagnosed the fault - outlet pipe blocked.  Cleaned it all out and it's pumping again.  It's also pumping hot soapy water over the dishes at the appropriate stages in the cycle.  I'm not sure about the rinse stage - the water looks too mucky, and has more foam in it than I would expect.
But the main problem is that the dishes aren't coming out clean.
Anyone got any suggestions?  I wonder if the pump has lost power and isn't shifting enough water at a high enouh pressure, but I've not really got a clue. :(
Re: Dishwasher, this time...
« Reply #1 on: 05 July 2010, 12:25:31 »
erm, Checked her Pulse, checked she is feeling ok?
Missed her Birthday / Anniversary?
Asked if there are any reasons why she is not doing the dishes properly?
 ;D ;D ;D
markspark
  • Bolton
« Reply #2 on: 05 July 2010, 12:43:01 »
pmsl  ;D ;D ;D ;D :y
jereboam
  • Suffolk
« Reply #3 on: 05 July 2010, 12:54:02 »
 ;D ;D ;D
Thanks to Unemployment, I am in charge of domestic services round here.  The management hasn't washed a dish since I got made redundant.  The management is also the sole income earner, so I do what I'm told. :(
Sixstring
  • Lydney, Gloucestershire
« Reply #4 on: 05 July 2010, 12:57:54 »
OK then.............
firstly put a proprietory dishwasher cleaner through it, (eg Finish or similar), then flush through with a hot clean with out any powder/rince agent in it. then, because the pump is not very strong (whatever the make) make sure the waste pipe is not too high, long, or kinked.
Lastly, the inherrent problem with ALL dishwashers is the drain in the bottom, keep it clean and unobstructed with food that comes off of the dishes you put in it, unless you clean out this it will be slow to empty and leave dishes dirty.
PLEASE NOTE: This advice comes from my brother, who installs white goods for a living.  Good Advice from a CAR forum...............
« Last Edit: 05 July 2010, 12:59:08 by Sixstring »
« Reply #5 on: 05 July 2010, 13:36:29 »
What sort of detergent are you using J – and, forgive me, are you using the correct programme?
As SS has suggested, these may be issues that result from the lack of adequate drainage.  As you've cleared the outlet pipe and the filter, the restriction may be further along the drain.  In a lot of cases when dishwashers are under-used or used at low temperature cycles, fat and soap deposits accumulate in the drain restricting the diameter and causing a degree of back pressure.
Assuming your machine drains into a standard 40mm pipe and thence into the main foul water drain you may have to check this 40mm pipe for obstructions.
« Reply #6 on: 05 July 2010, 16:08:47 »
Time to clean out entire machine. Not just the filters, but the sump, and the corregated pipe.  Also, ensure the spray arms haven't got bits of food/plastic/general crap stuck in the holes.
Then its worth using a proper dishwasher cleaner as suggested - I use Finish, but only because its always on offer at the cash and carry, else I'd use Tescos!  Occasionally, I give ours a minimal load, but use the mega hot/long wash to help keep it clean (though in my case, thats normally because assorted car parts are in there, and she gets a right monk on if I wash them with the dishes)
bertiecbx550
« Reply #7 on: 05 July 2010, 16:46:21 »
Is it me or have all the responses only come from blokes?? ;D ;D ;D ;D ;D ;D
« Reply #8 on: 05 July 2010, 16:49:10 »
just had an email from Aldi...
they have dishwasher cleaner on special this week
http://www.aldi.co.uk/uk/html/offers/special_buys.htm
Mysteryman
« Reply #9 on: 05 July 2010, 16:53:46 »
Aldi email you?? Sad, very sad. ;D
« Reply #10 on: 05 July 2010, 16:54:55 »
Yep, the email was about SDS drills....just happened to have some womens stuff on it too  :-[
« Reply #11 on: 05 July 2010, 17:04:34 »
Costco frequently have the Finish ones at BOGOF, so £5 (+VAT) for 2 ;)
jereboam
  • Suffolk
« Reply #12 on: 05 July 2010, 17:05:27 »
I've done the dishwasher cleaner business, and I've cleaned out the bit at the bottom where the rubbish accumulates.  However, I expect that there are some hidden areas I haven't got to yet, and there may be crap there.  I think the outlet hose is OK, because I  had it emptying into bucket, and it was flowing quite well.
I was using Fairy tablets, now I'm using Morrison's Cyclon tablets.  And, as we've had the machine for 12 years, I'm fairly confident I'm using the right program.  Especially since I had to replace the casing for the control module last year after the program selection became somewhat random.
And when I cleared the obstruction in the outlet, I took the opportunity to clean, degrease and bleach all the undersink pipework.  So I don't think it's an an outlet blockage.
Think you're right - there's probably hidden crap somewhere.  I don't think there's a problem with the spray arms, and there's a reasonable flow through the outlet pipe.
I may try an "intensive" wash to see if that clears it out, but I'll see what I can take apart first.
Thanks, everyone.   :) :) :)
jereboam
  • Suffolk
« Reply #13 on: 05 July 2010, 17:12:31 »
It was Aldi dishwasher cleaner I used after clearing the blockage.   :)   I bought it last time it was on offer.  :) :)  I might have a go with Finish, but at £3 a go, I don't buy it unless it's on offer.
And what's wrong with getting the Aldi offers e-mail?  Mine's just arrived, along with the one from Lidl.
Debs.
« Reply #14 on: 05 July 2010, 17:19:50 »
Isn`t an 'SDS drill' classified as women`s stuff? ::)
.....I rather fancy it is-so at Deb`s towers. ;D
