Author Topic: Car Mechanics Mag  (Read 1074 times)
Iain
Car Mechanics Mag
« on: 16 August 2010, 09:24:43 »
I just found in a drawer the above magazine with the Omega 4 pot timing belt change article
Now it is done on a 2.0 but i take it this is just exactly the same as the 2.2?
I assume it is just want it confirmed please :y
Re: Car Mechanics Mag
« Reply #1 on: 16 August 2010, 09:50:11 »
That article has a fair few errors in...
ALL omegas with BELTS have a 40k / 4 year interval for change, and should always be the kit as the tensioners are the normal weak link.
Iain
« Reply #2 on: 16 August 2010, 09:54:38 »
Yeah i knew that Jim,just wanted to check the 2.2 was the same procedure..timing marks etc,you know how GM a good at making subtle differences to make it akward
« Reply #3 on: 16 August 2010, 10:02:54 »
yes
Iain
« Reply #4 on: 16 August 2010, 10:43:42 »
Cheers TB,mine has a slight 'noise' almost like an older style timing pinking noise now and then,at the meet,Welung666 reckoned the timing may be a tooth out on the inlet side so i wanted to check it out.
It had a belt done about a year and half ago
« Reply #5 on: 16 August 2010, 10:51:35 »
Easy enough to visually check on those - aux belt off, cover off, TDC, check :y
Iain
« Reply #6 on: 16 August 2010, 12:33:54 »
If i check it at least i know either way
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
« Reply #7 on: 16 August 2010, 15:02:29 »
....and don't forget to change the water pump at the same time....
I like red cars
Iain
« Reply #8 on: 16 August 2010, 15:54:19 »
It was only done about 7/8k ago AA,so i'm not changing it just yet, i just want to check it by lining up the timing marks to check its spot on..
There is a chance it could be a tooth out.... so i want to know for sure
Auto Addict
  • North Birmingham
    • Astra K Elite ST
« Reply #9 on: 16 August 2010, 16:19:46 »
That's OK. just pointing out, I don't think Car Mech. mention the water pump.
I like red cars
Iain
« Reply #10 on: 16 August 2010, 16:33:05 »
I think it does show them doing the pump....
But yeah i would do it,dont see the point of stripping it all down that far and leaving an old pump in it! ;D
