Author Topic: Thinking of buying a plastic welder.  (Read 1318 times)
Martin_1962
« on: 21 August 2010, 19:12:37 »
Are they any good?
Would anyone want any welding done?
Re: Thinking of buying a plastic welder.
« Reply #1 on: 21 August 2010, 20:12:02 »
Are they any good?
we used to have one where I was made redundant from. That worked OK, just practice. It was just a heater inside & you fed it with low pressure air so it produced very localised hot air. Then you need a suitable filler plastic rod.
« Reply #2 on: 21 August 2010, 21:05:34 »
Are they any good?
[/highlight]
Well my right knee 'gives way' now & again Martin, so I may need the odd tack here & there ;D ;D ;) :y
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
« Reply #3 on: 21 August 2010, 21:21:31 »
Ironing board needs extending now does it?
TuBy's new whipping boy.
tidla
  • solihull
« Reply #4 on: 21 August 2010, 21:30:41 »
apparently she doesnt need any help thanks..
:P
Ken T
  • Stockport
« Reply #5 on: 21 August 2010, 21:46:12 »
Going back on topic .......
I use something similar to this
http://cgi.ebay.co.uk/NEW-SMD-REWORK-DESOLDERING-STATION-SOLDERING-IRON-/380256134365?pt=UK_AudioElectronicsVideo_Video_TelevisionSetTopBoxes
Primarily for SMD rework, but the temp will go down to about 100C, so will melt plastic OK. I used it to stick my power sounder back together once I replaced the batteries, worked OK.
Ken
tidla
  • solihull
« Reply #6 on: 21 August 2010, 21:55:10 »
Ken
cheers ken :y
« Reply #7 on: 21 August 2010, 21:56:43 »
:P
Oh i think she does....!         ;D
« Reply #8 on: 21 August 2010, 22:08:02 »
Ken
Mmmm,nooooh....(I think)  the ones I've seen are far bigger and totally hand held, gas powered flame, or possibly soldering iron style, with a a beed of plastic fed in on a trigger. Main trick is matching the correct plastic beed to the part being welded, ok omega bumpers will be all the same to a point I would think, but matching flame heat, trigger speed and movement of the gun takes a bit of fiddling around iirc.
But on the other hand, the main application I witnessed was repairing bike fairings(not all of them mine  ::) ) where the manufacturers chopped and changed plastic types year on year and to achieve different colours I think, so it may be easier on one make of car...?
Anyway, Mr Imber, have we cracked a bumper per chance?
Ken T
  • Stockport
« Reply #9 on: 21 August 2010, 22:33:06 »
You can draw an analogy with metal welding here. The hot air devices are like gas welding, what Chrisgixer described, feeding in the filler rod sounds like a Mig welder. Both techniques will work, although for fixing a crack that doesn't need filler the hot air might be better. Plus it would be handy for removing/replacing SMD components, as found in key fobs......
Ken
« Reply #10 on: 21 August 2010, 22:41:30 »
Yeah, would depend on the application.....?
Martin_1962
« Reply #11 on: 21 August 2010, 22:52:53 »
Large split in the front panel of the caravan, this is Baileys fault not mine.
Was going to do MEK and ABS extrusions but Plastruct have gone styrene, and MEK is not easy to get anymore.
Found the plastic welding and thought hmmm.
Got a cracked A frame cover as well
« Reply #12 on: 21 August 2010, 23:07:09 »
For a caravan.....?  Blu tac? Wottle and dawb, twigs and bailing twine?.........drill holes and cable tie?.........
White(or baige) gaffer tape?
Debs.
« Reply #13 on: 22 August 2010, 08:43:59 »
 ::) Wouldn`t a "Plastic Welder" be a little like a "Chocolate Fireguard" :P
 ;).....;D.....:D
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
« Reply #14 on: 22 August 2010, 13:09:19 »
Ignore them Martin, they're only jealous :D
I like red cars
