Author Topic: ISS Visible tonight.  (Read 1709 times)
Debs.
« on: 02 September 2010, 14:02:07 »
According to http://www.heavens-above.com we get a couple of over-flights by the International Space Station tonight.
Here in North Wales there will be three opportunities to see it pass, beginning: 19.15, 20.50 and 22.25 (all times BST) with each pass lasting 4-5 minutes 'horizon to horizon'.
Using the Heavens Above website, will enable you to enter your location and see times, vector and altitude in "ISS - All Passes".
You can`t mistake ISS for anything else overhead; it`s large, bright and fast moving!
Get the binoculars out and see if you can see the station`s solar array during it`s over-flight. :y
Re: ISS Visible tonight.
« Reply #1 on: 02 September 2010, 14:04:58 »
hoping its clear in newent, normally good visibility there  :D
Debs.
« Reply #2 on: 02 September 2010, 14:12:12 »
 ;) Stop rubbing it in!......You know I can`t go! :'(
« Reply #3 on: 02 September 2010, 14:13:51 »
Organise the Debs towers meet then, and we will come to you  :P
 :D :D :D
Debs.
« Reply #4 on: 02 September 2010, 14:18:24 »
 :D :D :D
 :y Deal! :y
« Reply #5 on: 02 September 2010, 14:27:24 »
 :D :D :D
 :y Deal! :y
Thats sounds good to me :y
« Reply #6 on: 02 September 2010, 17:27:25 »
Although no use for the ISS, I will be bringing a basic telescope to Newent this year
« Reply #7 on: 02 September 2010, 17:35:55 »
Aliens.....from the planet Yadddggerdta.....perhaps.....thanks for the info Ms Debs.... :-* :-* :-*
« Last Edit: 02 September 2010, 17:37:03 by optimist »
Debs.
« Reply #8 on: 02 September 2010, 21:01:16 »
Just been outside watching the ISS pass overhead; the perceived speed and brightness on approach was most impressive and the multiple sunlight reflections from the ISS`s solar arrays was clearly evident (even using my el-cheapo binoculars).
Well worth being eaten alive by my garden`s nocturnal midgies! :y
« Reply #9 on: 02 September 2010, 21:09:32 »
Good spot!
Its quite bright here, so not very good for spotting things  :'(
« Reply #10 on: 02 September 2010, 21:55:11 »
Seen :y  Impressive indeed 8-) :y :y
Broomies Mate
  • Bristol, UK
    • Stuff!
« Reply #11 on: 02 September 2010, 22:21:28 »
According to the site, it should be passing again in about 10 minutes (for those in the south of England).  Will be very low in the sky though, so might not catch a glimpse at all.
tidla
  • solihull
« Reply #12 on: 02 September 2010, 22:47:37 »
is that in wales...
cant be, not enough  LLsss
