Author Topic: Computer question for a numpty  (Read 1336 times)
« on: 27 September 2010, 22:42:17 »
My laptop will not connect to the Internet..... :'( :'(
Signal is good, swmbo is using hers, mine shows a signal but will not connect. I have done a few restarts and it goes to BT openzone, change it to ours, press connect and after a while of searching no connection..any thoughts, simply please.... :-[ :-[
Using my dongle and working fine.... ::) ::) ::)
maria
  • Derbyshire
  • I'm proud to be welsh :)
Re: Computer question for a numpty
« Reply #1 on: 27 September 2010, 22:44:21 »
you need sammy the sledge hammer ;D ;D ;D :D :D ;D ;D :y
Ian_D
  • York
« Reply #2 on: 27 September 2010, 22:44:47 »
Check you have correct WEP / WPA password.
Also check your IP settings are set to Obtain automatically.
[size=12]
« Reply #3 on: 27 September 2010, 22:45:14 »
PMSL   [smiley=2vrolijk_08.gif] [smiley=2vrolijk_08.gif]
Ian_D
  • York
« Reply #4 on: 27 September 2010, 22:46:31 »
Also try turning router off for 10 seconds, then back on again  :y
[size=12]
« Reply #5 on: 27 September 2010, 22:47:49 »
It had crossed my mind..... ::) ::) ::)
« Reply #6 on: 27 September 2010, 22:51:14 »
[/highlight]
It is doing that, and router is working OK
Think this laptop needs a bloomin good sort out, running very slow on start up and connecting anyway... ::) ::)
Broomies Mate
  • Bristol, UK
    • Stuff!
« Reply #7 on: 27 September 2010, 23:03:46 »
The Missus has probably blocked your laptop on the Router.  ;D
Anyway.
Try a static IP,
Check FireWall Settings,
Other than that, it's technical stuff.
Chris_H
  • E London/Essex UK
    • Jag XF Portfolio S 3.0D
« Reply #8 on: 28 September 2010, 08:59:45 »
I've met a couple of Vista computers of late that will not show internet on IE.  You can go to CMD and ping any website successfully but no amount of playing will get IE (or Safari either in one case) to display web pages.
A complete re-install may have to follow.
First Vauxhall - PABX Cresta; Previous, previous Vauxhall - 3.0 12v Senator CD; Previous Vauxhall Omega Elite 3.0V6 Saloon Auto
Psychoca
  • Norfolk
    • Beaten up Mondeo TDCI ST.
« Reply #9 on: 28 September 2010, 09:31:37 »
Check the WEP/WPA settings definate first port of call...
Then check the router wireless access list (assuming it is enabled)...
« Reply #10 on: 28 September 2010, 21:05:18 »
Thanks Guys... :y
Tonight it connected first time without any problem, work that one out........ ::) ::) ::)
« Reply #11 on: 28 September 2010, 21:07:14 »
Thanks Guys... :y
you remember the password ?  ;D :y
« Reply #12 on: 28 September 2010, 21:08:46 »
Thanks Guys... :y
 :P :P :P ;D ;D ;D
