Author Topic: advice on buying a high mileage Corsa ?  (Read 1896 times)
Ken T
  • Stockport
« on: 02 October 2010, 11:34:28 »
I've just seen an 07 1.3CDTi Corsa for £4200. This looks good but the mileage is high 97,000.
What do you guys think ?. do the diesel engine's last, or are we likely to have bits wearing out like the turbo ?. I can't find any obvious faults on google, are there anything to look out for ?.
Also, I am not used to dealing with car dealers, how do you negotiate a good price ?. I need haggling instructions !.
Cheers Ken
davethediver
  • Blackburn, Lancs.
Re: advice on buying a high mileage Corsa ?
« Reply #1 on: 02 October 2010, 11:37:43 »
Not sure on the engine but the miles are high IMO for a small car has it been used as a pool car or is it ex rental? :-/ :-/
P.A. Caron de Beaumarchais
« Reply #2 on: 02 October 2010, 11:46:23 »
Cheers Ken
Pretty strong engine TBH, I know a few in Combo vans that are at the 200K mark.
It is high mileage, I would be chcking full service history etc.
Check the gearchange is not aloppy, tyre wear is even, steering feels ok and that the internal cabin temp can be changed ok.
I would guess its done motorway miles given the coverage in a short time
Ken T
  • Stockport
« Reply #3 on: 02 October 2010, 11:46:28 »
I don't know, it says one owner. Oops sorry got it wrong, its an 08 (58). Thats about 180 miles per day.
Ken
Terbs
  • Brackley/Wareham
  • The Freezer Geezer
    • CD Saloon 2003
« Reply #4 on: 02 October 2010, 12:21:55 »
Cheers Ken
My opinion is that the engine has done 97,000 miles so has everything else, unless it has had a lot of replacement parts,
so as Mark says....give it a really good going over :y
« Last Edit: 02 October 2010, 12:22:18 by terbert1 »
Ken T
  • Stockport
« Reply #5 on: 02 October 2010, 12:28:05 »
It seems that some are prone to snaping a camshaft, or both. Sounds a bit  :-X
Ken
« Reply #6 on: 02 October 2010, 12:36:46 »
Ken
Lol, not the 1.3 CDTi
Some 1.2 and 1.0's with mega poor servicing.
Easy to check these to, just pop the cam cover off, see how filthy it is and torque the cam caps down again.
wingman
  • Hastings
    • Grandland GS
« Reply #7 on: 02 October 2010, 12:40:05 »
As another member said - check gear linkage as prone to wear (wife's cost £170 to renew and fit). Also check carpets for damp, especially drivers footwell as known problem with water leaks from around brake servo in this area. In any case with that mileage I think I would give it a miss IMO.
« Reply #8 on: 02 October 2010, 14:32:36 »
You were robbed, 35 quids worth of bits and 30 mins to fit.
Note that this will be a corsa d so quite a bit different to the c
Ken T
  • Stockport
« Reply #9 on: 02 October 2010, 19:22:13 »
Just had a look, it is showing the 97K mileage, lots of scratches, small dents, bumps, tyres nearly gone, bumpers both with dents, condensation in headlamps, looks worse than our current corsa.
Thanks for the advice,
Cheers Ken
scimmy_man
  • yorkshire
« Reply #10 on: 02 October 2010, 23:30:44 »
unless its very cheap and you have cash in hand "just in case" I would look elsewhere.
Amigo
  • Immingham N.E Lincs.
  • Be objective, be selective.
    • Passat & Cortina GXL
« Reply #11 on: 03 October 2010, 01:54:20 »
Cheers Ken
Mileage or otherwise this one does'nt seem to be "cared for". I'd give it a swerve, plenty to choose from & what with chrimbo coming up sellers will love you. BE FUSSY.
   You'll find better. 8-)
« Reply #12 on: 03 October 2010, 09:16:01 »
Very strong engine, does the miles really well, I honestly think it's one of the best engines out there.
