Pages: 1 2 3 4 5 6 7 [8]   Go Down
Author Topic: Potterton Suprima  (Read 17812 times)
Re: Potterton Suprima
« Reply #105 on: 26 December 2010, 03:15:21 »
Should be able to view the manual on line? Tried googling? I guess ypu must havevto find this thread. Boiler should have installers details on it somewhere. Might be a drop down panel at the bottom with some instructions perhaps?
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
« Reply #106 on: 26 December 2010, 10:24:30 »
Hi all
Just come across your forum and hope you can help with my problem (well rather my daughters).
Had a lovely Christmas dinner then daughter realised boiler was not switching off, even though thermostat was down to below 15.  We left her at 8pm and she called in panic at 11pm to say it was still running even though she has turned heating off completely..She lives in rented house and agents answer machine says "no one available until 4th Jan" .. I would be really grateful for any suggestion as to what she should try, she has 2 small children and a limited budget so is scared of calling out someone herself. :(
You will also find in-depth help on the DIYnot plumbing forum.
HTH :y
pscocoa
  • Sandhurst Berkshire
    • Volvo V90 D5 & Grandland
« Reply #107 on: 26 December 2010, 16:07:59 »
When I started this thread I had a pcb problem where boiler fans kept running even when turned off. Changed pcb and problem sorted. But they are not cheap Suprima is about £180 and Suprima HE £120 or so.
« Reply #108 on: 26 December 2010, 23:29:33 »
Hi all
My first guess is that you have a motorised valve that has stuck.
They should open when the thermostat calls for heat and spring closed when not.
A microswitch in the valve activates the boiler when the valve opens. If the microswitch fails or the valve sticks open, the boiler won't shut off.
There should be a spur box near the boiler to isolate the supply to the heating controls. Switching that off will stop the boiler cycling constantly.
Pages: 1 2 3 4 5 6 7 [8]   Go Up
