Author Topic: Computer issue  (Read 2885 times)
Terbs
  • Brackley/Wareham
  • The Freezer Geezer
    • CD Saloon 2003
Computer issue
« on: 15 January 2011, 17:37:49 »
Hi all..
Any ideas on this one !!!!!!!!!
Computer starts to boot up...gets to Windows emblem...then cuts out. >:(
Next try goes to 'Last known config/Safe mode' page.
Have got it started in safe mode....I then shut it down, restarted and it ran perfect. Restarted a few more times ..no problems.
Leave a few hours and it does it again. Once it has booted up it runs fine and dandy. :y
What I have done to try to remedy, is as follows.....fitted new HD (changed from IDE to SATA)...fitted new PSU...removed RAM and swapped around (fitting singly then doubled)....removed PCI-E card and used onboard graphics.
Only thing I have not done is removed CPU and Heatsink....could it be this?
Have reloaded Windows and updated to SP3.
Personally, I think it may have to be a case of strip it all out and start again. :(
Plomien
  • Swansea
    • Landrover Freelander TD4
Re: Computer issue
« Reply #1 on: 15 January 2011, 17:39:43 »
sounds like a program on startup causing the issue or a driver
Terbs
  • Brackley/Wareham
    • CD Saloon 2003
Re: Computer issue
« Reply #2 on: 15 January 2011, 17:51:11 »
Thanks Plomien.. :y
I never really thought about the drivers..
I have only put Windows Office, AVG Virus Scanner, the MB drivers (usb hub and Ethernet and video) and Nvidia driver for PCI-E graphics in....so I suppose its a wipedown and start afresh, trying after windows initial install, then invidual drivers and programmes. :y
If the Heatsink fan was under load at startup, would that shut the system right down.
BTW, when I say it shuts down, it is a full shutdown (audible click then instant total power off)...not a restart shutdown........ :y
Plomien
  • Swansea
Re: Computer issue
« Reply #3 on: 15 January 2011, 18:10:52 »
to check the cpu heat strain download speedfan to monitor the temp :y
Re: Computer issue
« Reply #4 on: 15 January 2011, 18:21:19 »
Given the symptoms, I'd be more inclined to think about an update coming down...
Re: Computer issue
« Reply #5 on: 15 January 2011, 19:28:31 »
check the system , application events and also bootlogs
Terbs
  • Brackley/Wareham
    • CD Saloon 2003
Re: Computer issue
« Reply #6 on: 15 January 2011, 19:40:53 »
Where is this info...in the Bios ?? :)
Re: Computer issue
« Reply #7 on: 15 January 2011, 19:41:53 »
Start > Run
eventvwr
will get logs
Terbs
  • Brackley/Wareham
    • CD Saloon 2003
Re: Computer issue
« Reply #8 on: 15 January 2011, 19:46:53 »
Thanks J  :y
« Last Edit: 15 January 2011, 19:56:24 by cem_devecioglu »
Terbs
  • Brackley/Wareham
    • CD Saloon 2003
Re: Computer issue
« Reply #11 on: 15 January 2011, 19:59:08 »
Thanks Cem :y
Following all advice given :y
Re: Computer issue
« Reply #12 on: 15 January 2011, 20:00:27 »
Thanks Cem :y
 :y :y
Mysteryman
Re: Computer issue
« Reply #13 on: 15 January 2011, 20:01:22 »
Re: Computer issue
« Reply #14 on: 15 January 2011, 20:03:52 »
Also check here
www.buyanewcomputeryoutightbastard.com :y
 ;D ;D STMO as usual ;D from where the hell you find that ;D :y
