Author Topic: images.omegaowners.com not responding for anyone?  (Read 1849 times)
« on: 14 March 2011, 15:27:22 »
It's broken for me...
Code: [Select]
trinity:~ aaronjb$ ping images.omegaowners.com
PING images.omegaowners.com (69.163.225.236): 56 data bytes
Request timeout for icmp_seq 0
^C
--- images.omegaowners.com ping statistics ---
2 packets transmitted, 0 packets received, 100.0% packet loss
trinity:~ aaronjb$ curl http://images.omegaowners.com
curl: (52) Empty reply from server
A tcpdump shows L4 is fine, a GET is sent and the server sends nothing in response (the TCP connection eventually just times out and dies)
(N.B. I expect the ping not responding is normal, that was just to get the IP for the tcpdump ;) but the 'curl' failing isn't normal..)
Re: images.omegaowners.com not responding for anyone?
« Reply #1 on: 14 March 2011, 15:33:34 »
I wish I knew the answer for you Aaron, but I don't even understand the question!! ::) ::) ::) :-[ :-[ :D :D :D
« Reply #2 on: 14 March 2011, 15:33:55 »
works here, although the response times are a bit lame:
Last login: Tue Apr 20 20:02:30 on console
marksmac:~ tunnie$ ping images.omegaowners.com
64 bytes from 69.163.225.236: icmp_seq=0 ttl=52 time=181.349 ms
64 bytes from 69.163.225.236: icmp_seq=1 ttl=52 time=186.369 ms
64 bytes from 69.163.225.236: icmp_seq=2 ttl=52 time=182.216 ms
^C
3 packets transmitted, 3 packets received, 0% packet loss
round-trip min/avg/max/stddev = 181.349/183.311/186.369/2.191 ms
marksmac:~ tunnie$
« Reply #3 on: 14 March 2011, 15:42:01 »
Weird.. if it was broken-broken then it'd be broken for everyone I'd have thought, but it doesn't look like a routing problem (which would affect just me) either since I do get return packets from the server:
(SYN,SYN-ACK,ACK works fine, GET is sent.. then 12 seconds later the server sends me a FIN without sending any data - ignore the checksums being wrong, that's checksum offloading happening on my client)
« Reply #4 on: 14 March 2011, 15:42:46 »
its being a little intermittant here.
« Reply #5 on: 14 March 2011, 15:46:13 »
Yes it's slow here.
The news banner and poll button isn't loading.
« Last Edit: 14 March 2011, 15:47:54 by Zulu77 »
« Reply #6 on: 14 March 2011, 15:50:50 »
As your on a 192.168 range, I'm assuming your at home not at work?
I've been having trouble recently with FIN packets on broadcast unit at work, they are being blocked by some internal firewalls as they are being read as invalid.  :-/
But as others have said its affecting them to, maybe TB's image server is firing blanks  ;D
« Reply #7 on: 14 March 2011, 15:57:50 »
I'm at work tunnie - 192.168.163.x is the range for this quarter of the UK office ;)
It's not working via 3G on the iPhone either, though, so it doesn't look like it's a Firewall/network issue internally..
« Reply #8 on: 14 March 2011, 16:06:24 »
My bad, assumed 192.168 you would be at home, not been at an office which uses that range for work use!
Interestingly though, I just got a 100% failure rate from my iPhone:
« Reply #9 on: 14 March 2011, 16:42:09 »
Our host for the images server has confirmed their network is feeling poorly, and is awaiting a parcel from those arseholes nice people at cisco
« Reply #10 on: 14 March 2011, 16:52:48 »
Project bodge implemented until I get home. Don't mOan the template is buggered
« Reply #11 on: 14 March 2011, 16:57:16 »
Hurrah!
Actually I quite like the grey colour scheme ;)
« Reply #12 on: 14 March 2011, 17:01:29 »
Ah now I know what you were saying Aaron!! ::) ::) ::)
Now mine is all a lovely grey, with no pics no logo!  Rather refreshing! ;D ;D ;D ;D ;D ;)
I have noted your comment Jamie, just didn't know until now what it was all about ::) ::)! :y :y
« Last Edit: 14 March 2011, 17:02:57 by Lizzie_Zoom »
« Reply #13 on: 14 March 2011, 17:09:12 »
Sorry Lizzie, I went straight off into tech-speak since I figured TB would be around, and I ought to include all the relevant info in case it was any use to him in diagnosing the issue :)
« Reply #14 on: 14 March 2011, 17:11:39 »
I'm with you Lizzie, but just assumed we needed another hamster in the wheel!  ;D ;D
