Author Topic: Big Thanks to Mark DTM  (Read 1109 times)
« on: 20 March 2011, 21:35:27 »
Been up in Nottingham for the week, and huge thanks to Mark for a few jobs on the car...
I now have shiny new shocks and springs at the front (gen VX LSC items) to match the rear.....Have to have a trip to Bolton this week now and get her set up, much better ride now, it had one aftermarket shock, which was a little on the tired side, and one original, which was virtually dead.
He also got to the bottom of my very dodgy bonnet catch - despite our previous best efforts, it remained a 2 person job to open the bonnet, Mark cleaned off the pin, and removed some burrs, which gave an improvement, then 'mended' the bottom spring, by welding in replacement metal where it had worn, and straigtened it where it had been damaged by over pulling in the past (a temporary job till I buy a new bottom spring, but at least we've proved where the problem was, and I can now open the bonnet single handedly.  :D
And last, but not least, he soldered in an autodim mirror. Wow, never used one before, and the drive home in the dark was so much more pleasant with no glare from behind, I has always assumed they only dimmed uber-bright lights, but no, any headlights get dulled.  I'd always ummed and ahhed about this, but the glare seemed to have got worse lately so decided to go for it.  Wish  I had done it years ago.
And of course, thanks again for your Hospitality Mr and Mrs DTM, much appreciated, we all had a very good weekend.  :y
Re: Big Thanks to Mark DTM
« Reply #1 on: 20 March 2011, 22:30:51 »
That man is a star, he's helped me with countless jobs on the tunnie family fleet of Omega's  :y
« Reply #2 on: 20 March 2011, 22:32:31 »
Good work from the master.  :y
How does that spring in the slam panel come put Jb, do you know?
Got one here that's worn and bent causing the catch to stick. Afaict  :-/
« Reply #3 on: 20 March 2011, 22:36:32 »
I dont....but I know a man who does, and he did mention a maint guide...
From what I watched, you remove the easy end so thats free...
and the end you cant see underneath, was basically held in place with an arrangement like mountain bike brake caliper which you had to negotiate out blind.
Ive got the part number in my wallet if you want that - the top spring comes in at just £1, so cant see it being much more than that.
« Reply #4 on: 20 March 2011, 22:43:37 »
Yes please, it will help being able to see the other end, fighting blind otherwise. No rush though it's on the other car.  :)
« Reply #5 on: 20 March 2011, 23:23:51 »
He knows quite a bit about lots of things doesn't he! He even knows about diseasal Zafiras  ;D ;D. A lad a work was gobb smacked when I showed him where his OBDII socket was & how the 'pedal trick' worked on his Zafira ............... all via OOF pm
« Reply #6 on: 21 March 2011, 07:57:28 »
Glab its better as a result.
I will order a spring today and carry out a (needless) replacement on my Omega and create a how to.
Its not to hard to change (and easier if the rad cover comes off!).
« Reply #7 on: 21 March 2011, 08:45:22 »
Just rang the dealer...
90494843 is the spring at £2.35 plus vat
ive also got a new spring clip for the release cable 11070693 at a bank breaking 5p + vat  ;D
and both in stock!
