Author Topic: Bu**er it's failed.  (Read 1992 times)
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
Bu**er it's failed.
« on: 01 June 2011, 17:46:41 »
Small hole on the inner wing near the steering box mounts. :(
Looks like TG will be playing with the welder again soon. ;D
TuBy's new whipping boy.
Re: Bu**er it's failed.
« Reply #1 on: 01 June 2011, 17:48:28 »
Bad luck...how come yours can fail, isnt he mot trained yet  ;D
CaptainZok
  • Bolton
    • 3.2 MV6 Estate
« Reply #2 on: 01 June 2011, 17:55:07 »
He's barely housetrained. ;D
Nope he's another two years at college before he can do the testers course so one of the other guys had to do it.
Not too bad really, easy enough access with the wheel off.
« Reply #3 on: 01 June 2011, 19:04:32 »
That's where mine has just been welded due an advisory last year.  ;)
Ian_D
  • York
« Reply #4 on: 01 June 2011, 23:41:31 »
Is it a common area for them to rust then?
I've noticed that the inner wing / chassis leg area on mine are starting to look a bit on the rusty side in places :'( That said, it passed the MOT on Saturday  :y
[size=12]
« Reply #5 on: 01 June 2011, 23:44:05 »
I've noticed that the inner wing / chassis leg area on mine are starting to look a bit on the rusty side in places :'(  ......
get it covered in something like Dinitrol before it gets worse. :y
CaptainZok
  • Bolton
    • 3.2 MV6 Estate
« Reply #6 on: 02 June 2011, 20:20:55 »
A couple of pics.
His Lordship has just finished migging a plate on and covering it up with underseal so hopefully it'll pass tomorrow.
« Reply #7 on: 02 June 2011, 20:23:53 »
The body shop unbolted my steering box so they could weld up around & about the chassis leg.
Ian_D
  • York
« Reply #8 on: 03 June 2011, 10:45:17 »
Ah mines not that bad!
Guess its a case of getting the wire brush out and seeing what its like under the paint thats starting to lift - if its fine, then slap a load of Dinitrol on then?
[size=8]** Goes off to google Dinitrol as I've no idea what it is**[/size]  ;D
[size=12]
« Reply #9 on: 03 June 2011, 11:00:51 »
think 'Waxoyl'  :y
http://www.frost.co.uk/automotive-rust-products/dinitrol-rust-prevention.html
CaptainZok
  • Bolton
    • 3.2 MV6 Estate
« Reply #10 on: 03 June 2011, 16:41:19 »
Well after TG's playing with the welder last night we now have 12 months ticket again. ;D ;D
« Reply #11 on: 03 June 2011, 17:58:32 »
 :y  :y  :y  :y
CaptainZok
  • Bolton
    • 3.2 MV6 Estate
« Reply #12 on: 03 June 2011, 19:22:05 »
Just got to fix the self levelling pipe he managed to nick with the grinder now.
Can you get speedyfits for 3.26mm o/d pipe?
« Reply #13 on: 03 June 2011, 20:03:23 »
I wonder if you could find a bit of ordinary plastic airline with araldite that you could use as a speedyfit. I've some 6 mm tubing that has a 4 mm bore  :-/ :-/
« Last Edit: 03 June 2011, 20:03:52 by Andy_B »
Amigo
  • Immingham N.E Lincs.
  • Be objective, be selective.
    • Passat & Cortina GXL
« Reply #14 on: 03 June 2011, 21:09:01 »
The Zokmobile lives to fight another year, as does Ians! :y 8-)
