Pages: [1] 2 3  All   Go Down
Author Topic: Re-sealing bath  (Read 3607 times)
Re-sealing bath
« on: 28 June 2011, 20:18:21 »
So in my flat I need to re-seal the bath, a crack has developed around the edge, where the bath meets the tiles. I need to stop water getting in.
I was thinking of using something like this:
http://www.diy.com/diy/jsp/bq/nav.jsp?action=detail&fh_secondid=10548844&fh_location=//catalog01/en_GB/categories%3C{9372013}/categories%3C{9372031}/categories%3C{9372100}/specificationsProductType=sealants&tmcampid=4&tmad=c&ecamp=cse_go&CAWELAID=396930033
Is it best to chip out the old stuff with something like a small chisel? Or is it ok just to clean it up and use that stuff above?  :-/
Any suggestions welcome  :y
RobG
    • 16 plate Mokka. Vivaro
Re: Re-sealing bath
« Reply #1 on: 28 June 2011, 20:22:03 »
Re: Re-sealing bath
« Reply #2 on: 28 June 2011, 20:23:24 »
your too fat - you broke it. :D ;D
Re: Re-sealing bath
« Reply #3 on: 28 June 2011, 20:25:42 »
http://www.screwfix.com/p/no-nonsense-sanitary-silicone-white-310ml/47187
Plastic/acrylic bath or pressed steel :question
Plastic  :y
Thats much cheaper! Think there is one near me too.
Best to remove old stuff or just go over top?
Two people in the shower at once may have caused it  ::)  :-X  8-)
Lioned
  • South East London
Re: Re-sealing bath
« Reply #4 on: 28 June 2011, 20:27:42 »
That is one mighty  big crack.I think i would investigate a little further if that has moved to that extent or was it just badly fitted and the old stuffs fallen out ?
RobG
Re: Re-sealing bath
« Reply #5 on: 28 June 2011, 20:31:48 »
Clean as best you can. Run two strips of masking tape, one along the tiles, the other along the bath leaving a suitable gap between both strips. Fill bath 3/4 full then apply sealant in one continuous application. Wet finger and smooth off. Wait about 5 minutes then carefully remove tape and drain bath
Re: Re-sealing bath
« Reply #6 on: 28 June 2011, 20:32:52 »
Badly fitted.... quite a few little sections where it shows poor fitting. Shame, its good stuff but look like it would poorly put together by previous owner  :(
RobG
Re: Re-sealing bath
« Reply #7 on: 28 June 2011, 20:33:29 »
Looks badly fitted and not been sealed as per guidelines for acrylic baths
Re: Re-sealing bath
« Reply #8 on: 28 June 2011, 20:35:25 »
Perfect. Cheers Rob  :y
Good point on 3/4 bath, get the weight in there, and after it sets a little it will rise as it goes lighter! Did'nt think about that!
I'll post an after photo  :)
Re: Re-sealing bath
« Reply #9 on: 28 June 2011, 20:36:20 »
Plastic  :y
Get yourself a skinnier boyfriend or a stronger bath then. :y :D ;D
Re: Re-sealing bath
« Reply #10 on: 28 June 2011, 20:38:56 »
Plastic  :y
Considering my girlfriend is lighter than me, i'm the fat one  ;D
Re: Re-sealing bath
« Reply #11 on: 28 June 2011, 20:40:50 »
We believe ya Tunnie. ;)
Re: Re-sealing bath
« Reply #12 on: 28 June 2011, 20:54:20 »
I would still remove the bath side and see if the floor has rotten and sunk taking the bath with it. Raise via the feet if needed? Then re seal.
Re: Re-sealing bath
« Reply #13 on: 28 June 2011, 20:54:57 »
Who else thinks TB paid Tunnie a visit? ;)
Reminds me I really need to re-seal my bath after it dropped a bit.. in my case it really is because I'm a fat bastard, though  :-[
Lioned
  • South East London
Re: Re-sealing bath
« Reply #14 on: 28 June 2011, 21:03:55 »
Thats what i was thinking as it does look like it has shifted quite a lot and if that is so then it will continue to move however well you do the mastic now.Also maybe the bath has not been fixed in position properly as there would normally be a couple of brackets holding it to the wall and maybe the legs not bolted up very well.Definitely something not right there.
Pages: [1] 2 3  All   Go Up
